Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    Jul 2014
    Mint Hill, NC
    Who knows? Other than being terminally stupid, why would one consider himself smarter than the guys who designed the engine with two O-rings on the plug and leave them off when reinstalling the plug?
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
  2. #27
    Oct 2016
    Sebring, FL
    Good thought and well said JayBros.
  3. #28
    Jul 2014
    Mint Hill, NC
    Pardon my bluntness in my previous comment. The 1330 ACE engine has a dry sump lubrication system with multiple pumps continually working to lubricate the engine and return oil to the tank. Once the engine is turned off some oil in the tank drains back into the crankcase. When the engine is started scavenge pumps pump this oil from the crankcase back into the oil tank. It is possible that the O-rings on the plug are there to prevent oil from draining into the crank case while the engine is running, I don't know; it's just a WAG as to what the O-rings might do.
    Cognac 2014 RT-S
  4. #29
    Mar 2019
    lakewood ranch fl
    The question was because I had the dealer Chang the plug to the gold one at the 3500 service , and you never know.
  5. #30
    Jul 2014
    Mint Hill, NC
    Did the dealership replace the OEM plug with a simple Gold Plug with nothing more than a metal sealing gasket or did it use a Gold Plug that was in essence a hex head version of the OEM plug with the grooves for and O-rings installed on the plug?
    When the 1330 engine first came out in early 2015 Gold Plug advertised a replacement plug for the crankcase plug that was in fact nothing more than an M14X1.5 hex head plug. I pointed this out to the company they acknowledged they advertised the wrong plug and were in the process of manufacturing (or having manufactured) a correctly configured plug.
    Cognac 2014 RT-S
  6. #31
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Turns out it was a loose plug and bad crush washer. No leaks now so it’s good. Thanks for everyone’s feedback.
    Hers 2014 ST
    His 2016 RT Limited
    2016 RT Limited , White
