Results 1 to 25 of 31
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default T 45 Question about Oil Drain Plug
    Hello I have a question on the T45 plug I’ve never changed the oil on my 2016 RTL only because the dealer thru in a 2 yr free service when I bought it in 2018. My question is I’m leaking oil I thought it might be from the oil change but it’s still dripping so I did some checking and noticed that the plug was oily. Ok I put a T45 on a short extension and I notice it was crooked (at an angle when in)not straight up and down as I would have thought. I’m sure it’s the T45 a 6mm doesn’t seem to fit. Anyhow is that normal to be at an angle or should it be straight up and down for you that have changed your oil on the 1330. I’m due back at the dealers Saturday but I think they cross threaded that drain plug. Thanks for any answers. And this isn’t the first time the dealer did an oil change on my Spyder. Thanks Michrick
    Hers 2014 ST
    His 2016 RT Limited
    2016 RT Limited , White
    The crankcase plug hole is not vertical as the Spyder sits on a level surface. If you put your finger on the plug itself you will feel the angle. Therefore, if you insert a T45 bit correctly into the plug it will appear angled. The dealership would have had to really botch the process to cross thread the plug and you'd have a whale of a leak. I'll bet they simply did not change the O-rings and the aluminum washer.
    May 2015
    Liverpool, NY
    Thanks much JayBros for the info.
    Hers 2014 ST
    His 2016 RT Limited
    Jan 2015
    southern WI
    Agreed...they likely don't have a supply of crush washers or o-rings on hand so they just use the old ones multiple times. I'd recommend getting the Gold hex head plugs and the o rings/washers for this oil change you have in mind. It only takes a few days to get the plugs, and it'll save headaches in the future.
    2016 RTS , Pearl White
    May 2015
    Liverpool, NY
    Thanks Mazo EMS2
    Hers 2014 ST
    His 2016 RT Limited
    Sebring, FL
    Quote Originally Posted by Mazo EMS2 View Post
    Lamonster has the gold hex head plugs, right?
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    That's correct, He carries the plugs for both drains in a kit.
    .... I always had a problem only with the Torx head plug so I switched to the GOLD plug ...... Mike
    Sep 2018
    Caledonia,Ontario,Canada
    M12x1.5 plug same as Goldwing 2019, M14x1.5 plug same as Goldwing 1988-2017. Head to your Honda dealer! Both magnetic
    Sep 2014
    USA
    I am still fine with the factory drain plugs. Key is to use good correct tools that dont damage the drain heads. Also use a rubber sealed washer versus the copper ones.
    From what I've read here on SL the problem with the 1330 crankcase plug may have reasonably begun with DIYers who assumed since there was a hole in the plug it had to be an Allen so they stick in the closest fit, probably a 3/32", and that started things on the road south.
    Jun 2011
    Near Lexington, NC
    Yep, did exactly that on the T45 Torx side on previous '14 RT. Luckily, I didn't ream it out before finding out it was a torx and bought one. Doesn't make sense to me they use a torx on one side and 6mm allen on other!
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Houston
    Quote Originally Posted by Nobodyjj View Post
    Nope, not for a 1330 engine. The crankcase plug has 2 orings as it drains both the sump and the crankcase. Its a long plug with the threads on the far end.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Feb 2019
    Portland, Oregon
    The OEM drain plugs will last as long you use the correct tools and apply a steady force until it releases. Don't jerk around with the wrench or cheater bar, which is what I use.
    Sebring, FL
    It would trouble me to use a plug other than the one designed for the Spyder RTL such as the hex heads from Lamonster. I certainly don't enjoy spending the extra $, but peace of mind is worth something.
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    I thought about changing to those, but I read somewhere that they have a tendency to break.
    True ??
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Sep 2019
    Reno, NV
    Indeed.
    A cheater bar allows you to apply pressure at a steady rate far easier when compared to a shorter handle.
    Just make sure you're going the right direction, LOL.
    2002 BMW 325i - his
    Sebring, FL
    Quote Originally Posted by Peacekeeper6 View Post
    True ??
    Egads, hope not. I have not made a purchase yet, but I'm subscribed for any information that may follow.
    Sep 2019
    Reno, NV
    Didn't mean to scare you, but I think they were breaking when people are putting too much torque when reinstalling them.
    Don't quote me on that though....
    2002 BMW 325i - his
    Sebring, FL
    Entirely possible, when i did my oil changes on the GW Trike, I knew by feel how tight I should go, and never a weep, never a stripped thread, never problem. I think that should work on the Syder, no torque wrench flame pls, I might do the torque wrench.
    Jan 2019
    Kentucky
    Default First and Last Dealer Oil Change
    I found a Torx Bit Driven into the Allen Head Drain Plug.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by jiffy View Post
    A dealer shop did that? That's another reason why I do all my own maintenance.
    The engine is spic & span clean, that must be a new bike. Request a replacement plug from the dealer and save it for the next oil change which you will do, I hope.
    Sep 2014
    USA
    take it back if the dealer did it and have them replace the drain plug too.
    Jan 2019
    Kentucky
    I do all my own maintenance. The photo was from Fall of 2015. Replaced the drain plugs with Gold Hex Heads.
    Mar 2019
    lakewood ranch fl
    What would happen it the drain plug with the two O rings was installed with out the O rings ?
