Results 1 to 25 of 50
    Jun 2018
    Pa.
    Default Kanine tires not certified by BRP
    Hi All:
    I know the topic of tires can get ones hackles raised. Two dealers in the Pennsylvania area told me although Kanine tires are a Kenda product, BRP did not certify them yet. Is this true?
    Thanks in advance,
    Jim
    Jul 2011
    Mitchell, Ontario, Canada
    This is just my opinion. But who cares if if BRP certified them or not. Is this even a requirement for legal reasons anywhere?
    Feb 2020
    N. Wilkesboro, NC
    I agree w/Billy. Car tires aren't approved by BRP, either, but there may be more Spyders out there w/car tires than w/the original Kendas. I doubt it's an issue.
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    It can become similar to the ‘darkside’ argument. If you have an issue that the warranty agent can conceivably blame on using a car tire on a motorcycle warranty coverage can get to be a problem. Similarly, if a problem can be blamed on using a ‘non-certified’ tire......
    To satisfy my OCD I’d ask BRP IN WRITING whether use of the kanine can affect warranty coverage, and require the response IN WRITING.
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Quote Originally Posted by Stache View Post
    Firstly, the Rims on all Spyders and Rykers are 'J' type CAR rims, and the Kenda tires from BRP are NOT Motorcycle tires, they have CAR type beads to match the bead profiles on the rims and they have CAR tire construction, even tho BRP has printed some namby pamby made up 'Special Motorcycle' label to cover their arse if someone is stupid enough to fit an OE Spyder Spec Kenda tire on a car, cos the Kendas simply aren't up to it!! Plus, I believe the Kanine's and the OE spec Kendas even have a notice to the effect - 'Fit to 'J' type Rims ONLY' printed somewhere on their sidewalls; and btw, running 'J' type rims on a motorcycle is pretty much verbotten everywhere in the World that motor vehicles &/or motorcycles are required to be registered!
    And secondly, even if your OCD does call you to ask for something in writing, BRP is only ever going to say you MUST use their over-priced under-spec'd poorly constructed excuse for a CAR tire on all Spyders and Rykers anyway, cos that's where they'll get the most profit, so that's a pointless exercise from the get go!
    X's 10 ..... and the " J " on the tire sidewall is FACT .... so your " belief " is correct..... I have not been able to find the " for special motorcycle use only " .... as a legal designation for a tire listed by U.S. federal D.O.T. regulations !!!! ..... and the wheels BRP puts on all Spyders are stamped " J " type ..... Mike
    Since BRP is putting the Kenda Kanine on the newer Spyders. I'd say that's defacto 'Certification' right there. But I also agree with Billy. A manufacturer doesn't have to 'Certify' something for me to use it if I think it appropriate. There are many reasons a manufacturer does not certify a particular product. Sometimes it's to push you into buying their version with inferences to warranty issues. That gets a lot of people, when it really shouldn't.
    I've never heard of anyone having a non-certified tire warranty issue. In my opinion, it's a red herring. But an effective one. Just like with oil and other items. Fear (justified or not) can be an effective marking tool.
    May 2017
    Mesa, Arid-Zone-A
    I have Michelin tires on my Buick. As far as I know, Buick hasn't certified them..... ..... Jim
    Semper Fi
    Jun 2018
    Pa.
    The reason why I brought this up - in Pa. the dealers will not inspect your bike without tires approved by the manufacturer. In Pa. we need or are supposed to have yearly inspections.
    Thanks for the thoguhts.
    Jim
    Jul 2011
    That is the first I have heard that BRP is putting the Kanine tire on. I asked the dealer if they sold or would get the Kanine tire. They said no. That was in May.
    PS I just checked Kendas website and state specifically that it is aftermarket. But they also say it is the first and only aftermarket tire for the Can Am Spyder. Well that's not true. Arachnids were first and still available.
    Jul 2020
    Austin, TX
    My brand new 2020 Spyder RTL equipped with Kenda Radial, not Kanine.
    2020 Can-Am Spyder RTL
    2009 Yamaha V-Star 1300T (sold)
    2007 Yamaha V-Star 650 (sold)
    "I wasn't born in Texas, but I got here as fast as I could!"
    2020 RTL , Asphalt Grey Metallic
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    I kind of figured this was your concern, being in NJ close to PA. Fortunately, NJ no longer (for about 10 years now) requires motorcycles to be inspected.
    I purchased my ST from a dealer in PA, and had asked about eventually mounting non-Kenda tires...they told me they would do it without any reservations, though I would probably have to bring the tires.
    I would try other dealers. Or see about possible inspection facilities that are not at a dealer.
    Good luck!
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    "BRP Approved" means you're going to pay more MONEY for less QUALITY.
    I just use comparable sizes and good quality tires for my money. I got 2 Federal Formosa tires for the front and a Kumho Esta for the rear from Amazon for less than $200. I called my dealer and they said it would cost $65 to mount each front tire -off the Spyder- since they're not OEM tires. Discount Tire charged me $21 to mount and balance each. Money well spent there.
    Cheers.
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
    Nov 2012
    North Las Vegas, NV
    Sorry but I lived in PA until 2014, ran car tires had my Spyder inspected. Never a problem. All they looked at was how much tread was on the tires. RED HERRING!
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    Never had that problem when I lived in Pa. I went to independent shops for motorcycle inspections. Sounds like your dealer is telling a story.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Durham,Maine
    2012 RTL , Pearl
    Harrington, Australia
    The big question for me is - WILL my dealer fit Kanines?
    If they won’t then I won’t even consider Kanines and will keep mounting “car” tyres myself. (But I would rather NOT do it myself if I can avoid it).
    However, if my dealer WILL fit Kanines, (they won’t currently fit “car” tyres), then I will start looking at the reviews on the Kanines.
    I couldn’t care less if they have been certified by BRP per se, but if they haven’t, I believe there is a strong chance that those dealers who won’t fit “car” tyres won’t fit the Kanines either.
    HeliBars Handlebars
    Kenda Kanine rear.
    Sort of, Mikey .....but this is a bit different to the usual threads as the Kanines do have the “possibility” of being fitted by dealers.
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2014
    USA
    Would the D.O.T number not be enough that is stamped on the tire as a legal designation? Or are you referring to For Special Motorcycle use only term?
    I think that was just put on the tire to not mount it on a car wheel or use it on a car as some most likely would do.
    Apr 2020
    tucson az
    Legally there is nothing BRP can say or do. However you should be aware that if you are in an accident you could be held liable for not using the recommended tire or advertised replacement for that rim. And be found at fault for the accident even if it was obviously the other persons fault.
    2011 rt , pearl white
    Quote Originally Posted by JimH View Post
    Jim
    I think they have the same program in Russia!
    Quote Originally Posted by remus View Post
    I would like for someone to site for me a case where this actually happened.
    Quote Originally Posted by TXGreatRide View Post
    My salesman (who I see often) asked me if I wanted to see the 2020 RT They were un-crating. Of course, I did! It had Kanines on it. I only saw the one. But I can't believe it was the only one. I lamented to my salesman that I wished my Ryker had come with them. He said that it might happen on later models.
    All OEM tires on Spyders/Rykers are radial design. So, that is not noteworthy. Are you sure it does not say 'Kanine' on the tire somewhere?
    Apr 2020
    tucson az
    Lets start with this article written in 2012
    https://ridermagazine.com/2016/05/20...n-motorcycles/
    And look at your insurance policy last time mine was renewed there was a clause which states "must be maintained in a roadworthy condition". whats roadworthy? do you have a lot of $ to fight a legal action? I sure dont. If you don't know ask your ins. agent. And while govt is trying to take more of our hard earned money how much longer will it be before we go the way of europe? england has yearly motorcycle certifications and if you are darksiding it you have what is considered an unsafe modification you can't legally ride nor will your ins cover you
    Clinton, MS
    remus, you do realize that the Spyder uses a CAR RIM Spec's, not motorcycle rim spec's, right?
    Mar 2017
    Salisbury,NC
    I see you just joined in April, and have only 24 posts. After you ride your Spyder for a while (if its a new one), you will see how little miles you get out of back tire, and WILL want car tires on it. Then if the fronts are out of balance or don't grip well, there are many car brands available. Its not dark side like a 2 wheel mc, its J type rims, with J type wheels. This forum doesn't have to train you to try this, you can still use tires that are overpriced and wear out quickly. A lot good info above!!!! or by looking at older posts
