Results 1 to 12 of 12
    Jan 2019
    North Carolina
    Default Recommendations, cup and mount, 2013 RTL?
    Hi folks, 2013 RTL.
    Needing a mount and insulated cup for my sweetie behind me.
    Y'all are pretty good at these type of recommendations!
    Hopefully 24 oz or larger, with a straw.
    Thanks in advance!
    Aug 2018
    north wis
    Motorcycle Dave has a good holder that clamps on the rear hand holds.Recently got a couple Contigo cups from menards and they hold ice all day.About $10.
    Linden, CA
    Default Cup Holder
    Here you go $16.95 they work great
    Dave
    209-887-3283 motorcycledave@mac.com
    Quote Originally Posted by Jackhartjr View Post
    Hi folks, 2013 RTL.
    Thanks in advance!
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    i ran a wire tie between the 2 grip ends holding the bottle. my para noia says a couple big a--
    bumps might dislodge the bottle. havent tried it yet. just got the bottle. anyone have an
    experience with these coming loose.
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    May 2016
    mt morris il
    looks like when mounted the cupholder has to come off to open the side rear trunk door. any
    way to mount it so it wont . cant do it at an angle . wife says she can just hold the cup. guess were just back to carrying water in the trunks. dont want anything on the handlebar.
    Mar 2015
    forrest above Reno, Nv
    I have the one in " Motorcycle Dave's" picture. It is adjustable for height and mine clears the saddle bag lid when raised up ( One nut and bolt ). I rigged up a hose with bite valve and jacket magnet so its just a 1 hand operation for my wife to get a drink. 32 oz Pelican fits, used is on long trips and its never come loose.
    2014 RTS , Circuit Yellow
    May 2016
    mt morris il
    i did raise mine up and tried it on the hand grip. im not real trusting of that clamp. not much surround surface.
    i did massge the unit to get it raised . doesnt lock in like the center hole. lamont has the same unit as dave i believe.
    mine is mounted at the back of the hand rail for wife clearance. wheres yours. stayed on ok?
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    go to glassact.com
    they designed the perfect setup for both the driver and passenger
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    Aug 2018
    north wis
    Have been using that holder for 2 years now on my 18 then the 20. Cleared side bags on both(you can adjust the angle) and has never let go. I do make it TIGHT
    May 2016
    mt morris il
    had the lamonster holder and bottle. did end up ordering the drink2go spyder holder .
    more bottle arm arm holding ability and the grip area is better on the passenger grabrails. will see how it does. thanks for all
    comments and info. --irv
    Jul 2014
    Mint Hill, NC
    I've had one like Dave's picture, think I got it from Value Accessories when I first bought the Spyder. I'll tell you the clamping mechanism is so good that if you hit a bump big enough to launch the bottle out of it there will be three things in the air, you, sweetie and the bottle, but the holder will still be on the Spyder. It is easily adjustable so it does not interfere with opening a saddlebag.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jan 2019
    North Carolina
    Folks, I really appreciate the responses!
