Results 1 to 12 of 12
    Jun 2015
    Ritzville, Wa
    Default Ryker reverse tip/trick
    Here's a little tip I stumbled across on Youtube this morning......
    When shifting into Reverse on your Ryker, your told to hook the tip of your shoe under the shift lever and pull backwards. The other option of course is to bend down, grab the lever with your hand and pull back.
    Here's a third option. Instead of trying to hook the toe of your show under the shift lever, place your foot on top of the lever, apply a little downward pressure and then pull your foot backwards.
    I just tried it and it worked like a charm for me. Your mileage may vary.....
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Nov 2018
    N.E. Ohio
    Yes it does. Nice and easy solution! cueman
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Or rotate the lever on the shift shaft a couple spline positions rearward.
    Sep 2019
    illinois
    Quote Originally Posted by SportsterDoc View Post
    Have you done this? I tried a while back but bolt seemed awfully tight. I did not want to force anything. I was involved with a different project also and didn't want to get too sidelined.
    May 2020
    New Mexico
    Quote Originally Posted by canamryder View Post
    Yes, needed to keep ratchet on it full length, both in and out.
    Makes for finding reverse very quick
    My footpegs are full forward.
    Sep 2019
    illinois
    Who ever adjusted mine must have a 34+" inseam. I only have a 32" inseam. Your forward position is near where my reverse position is now. Well, maybe not quite that much. I may adjust tomorrow. Gotta ride first. Ryker today=50 miles, Trek bicycle 80? miles tomorrow. (low winds predicted) Ahhh..isn't retirement fun!!!
    Jun 2015
    Ritzville, Wa
    How do you do that?
    Greg Kamer
    May 2020
    New Mexico
    Unclip and remove the engine air filter assembly to access the forward reverse shift lever. It is the same design as a motorcycle with a direct connection to the shift shaft. Remove the bolt, pull the lever, reposition it, check that it's a comfortable position, reinstall bolt.
    Jun 2015
    Ritzville, Wa
    Thanks Doc, I'm gonna take a look at that. Always open to options.....
    Greg Kamer
    Sep 2019
    illinois
    I just finished moving mine a little while ago. A small gear puller? would have been handy. I struggled getting it off, then it popped off. Then I struggled getting started back on, then it started on. I tapped it lightly on the rest of the way with a small piece of wood and hammer. I also took off the extra linkage I was using to reach it. It may be in about the same position yours is now. While sitting on the seat and with it in "F" position, I can see about roughly 1/4" of it now. It should have been in this position in the 1st place! I lied on that bike mileage not 80 but 108 miles.
    May 2020
    New Mexico
    My shift lever came off with just a bit of wiggling. Otherwise a battery terminal puller could be used. They are inexpensive. It went back on with a couple gentle taps from a rubber mallet.
    The bolt did not come out smooth, as if the shift lever clamp holes were not perfectly aligned and it did not go back in smooth; although the applied torque was not excessive.
    Certainly makes for smoother reversing.
    Jan 2020
    California
    Hey Guys, thanks for this thread ! I've been avoiding using reverse for a long time because it was such a pain to use the shifter. I just removed it easily by tapping a screwdriver into the slot of the shifter and it came right off. I moved it about 20 degrees back and now life is good again. Small hint,,,, leave the screwdriver in place to reinstall the shifter.
