Madstad Windshield
My 2019 F3Limited with Screen,suits me fine very little buffing I am 5Ft 4,When my wife rides with me she is getting a lot of wind buffing,she is 5Ft, thinking of getting the 20inch Madstad screen,still want to look over it,open to all suggestions thanking you.
John
Reason: Madstad
John
The plus of the adjustable Madstad is that you can move it up and down and angle it forward and back, Patt. Others don’t offer that. The scenario you are facing is not one that I have experienced as I am 6’7” and any screen that comes to the tip of my nose (usually 25” (max heights), so I can still see over it while providing reasonable buffeting protection, provides great cover for my wife whose view basically consists of the back of my helmet .
It’s hard to nominate a screen height as we are all different body heights, even though we may be the same overall height. The only suggestion I can make is to get yourself a long piece of timber and a spirit level (or ideally a long spirit level), hold it level with your top lip and see how much extra height you can add on your current screen to still allow you to see over the top. Once you know that, you can do some comparisons of stock screen height with aftermarket screen heights......also the aftermarket guys will all provide help in getting the best height for you for their particular screen. F4 is also a great screen, albeit without the Madstad adjustability, that provides great protection. I have both the Madstad and the F4 on my F3-L, and prefer the F4, especially as it also has lower “wings” to provide even more protection for you and your passenger, but’s that’s me, and I am quite happy to ride behind the Madstad.
One thing I would caution you about, is accepting advice from others who are the same height. They have the best of intentions, but as I said earlier, we are all different body shapes and theirs might not fit you
Hope that provides some food for thought........good luck
Harrington, Australia
HeliBars Handlebars
Russell Daylong seat 2 taller than stock (in Sunbrella for Aussie heat & water resistance)
Goodyear Duragrip 165/60 fronts (18psi) - provides extra 1/2 ground clearance.
Kenda Kanine rear.
p.s. sorry, I should have mentioned the Lamonster type screens (I think they are called Freedom screens, but I could be wrong) that have a top lip, meaning the air is forced over the lip. This means you can get away with a shorter screen but still provide buffeting protection for you and your passenger.
HeliBars Handlebars
Kenda Kanine rear.
Thanks Pete,will also look at theF4 thank you
John
I went with the 15" Freedom windshield from Lamonster and it's huge improvement over the stock windshield, and the wife seems to be good with the wind delection, although I'm 5'-8" and she's at 5'-5".
Hey Pete do you have aircraft warning lights on your helmet?
HeliBars Handlebars
Kenda Kanine rear.
Pete ,I am swaying towards the F4 21” hope I can see over the top of it ,would it be possible to give me a measure height from the top edge of the Dash to 21 “ on your tall windshield,hope this makes sense.
John
Ozzie Ozzie Ozzie
Pete ,I am swaying towards the F4 21 hope I can see over the top of it, would it be possible to give me a measure height from the top edge of the Dash to 21 on your tall windshield,hope this makes sense.
John
John, if I have read your question correctly, vertically from the top edge of the dash (i.e. above the odometer) to a point 21 up the F4 from its bottom edge is between 12 and 12.5. I hope thats what you wanted. I have also messaged you.
HeliBars Handlebars
Kenda Kanine rear.
Have you seen this F4 sizing video, John?
https://youtu.be/aDiHnRkqeEU
HeliBars Handlebars
Kenda Kanine rear.
Thanks Pete, that is what I wanted much appreciated.
John
