Results 1 to 20 of 20
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    Default Belt tension, N vs lbft
    I know that 625n equals about 140 lbf, but if belt tension is set in the air as per BRP specs to 625n,(spec is 775n + or - 150n)
    will that tension go up or down with the wheel back on the ground, checked with a Krikit gauge ??
    thanks johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Sep 2014
    USA
    Then tension goes back up when on the ground.
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Krikit II Belt Tension Specs courtesy of BajaRon
    2014 RT-Ltd , Cognac
    Jun 2018
    Tonawanda, NY
    Purple Guy, I believe that there has been a TSB since the settings you submitted. The current spec is 775n +or- 150n
    USMC RETIRED
    BLUE KNIGHTS NYV
    Quote Originally Posted by johnv50 View Post
    thanks johnv
    Ron's chart shows the KritKit gauge reading needs to be LOWER if the wheel is OFF the ground .... I like 160 +/- lbs. ON -the-ground, I can't feel any Belt vibes .... On the ground checking, saves a Ton of time and effort, and if you use the right Lbs. amount .... you achieve the SAME thing ..... good luck .... Mike
    Jun 2018
    Tonawanda, NY
    If I read the chart right, in order to obtain 160lbf on the ground I need to set the tension to 450n in the air.
    Does this sound correct ??
    thanks johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    Active Member WDAVEY's Avatar
    Jul 2019
    FL in winter, CNY in summer
    Please be gentle, I'm new at this lbf vs n thing. I have a 2019 RTL with 4,500 miles. I get a slight "beat frequency" vibration most noticeable at 72 mph. My repeated readings on Krikit is 230# WOG. If I understand all the explanations above it should only be about 160#WOG. I just want to know the target before I start adjusting. TIA for your help.
    Quote Originally Posted by WDAVEY View Post
    If " WOG " is While On Ground ..then you are correct 160 lbs. +/- is what I have mine at ..... Mike
    SoFlo
    There is no approved spec for belt tension with weight on wheels. By jacking and tensioning the belt with no weight on the rear wheel, the suspension is at full extension, AND a repeatable position.
    Weight on wheels measurements can vary based on the true ride height. On some years with adjustable rear suspension, you could find that there is inconsistency between each person Spyder regarding actual belt tension per the manuals procedure if set with weight on the wheels.
    Most people that set their belt tension to the median spec of the TSB, measured with the suspension fully extended have had good results that are easily repratable.
    Sep 2017
    Durham,Maine
    So what your saying is that the more you load the suspension, the tighter it will get!! So if they are looking for a happy spot for the whole system, bearings, belt, ect, would it not be smarter to do that under a normal load set up? You take the bike, lift it, set it, then load it, and every one carry's different stuff, you don't really know what you got for shore on the belt!
    2012 RTL , Pearl
    Interesting ..... if your hypothesis is correct, when you take your measurements do you load up the Spyder with the same amount of weight that you expect to carry on that days rides ???? .... and what if that weight changes during the ride, do you then re-measure it ???? ... When I lowered my Belt tension ( because it was way to high from the Dealership ) I first did it with wheel OFF the ground, after I lowered the spyder to ON the ground, I took that measurement. .... Now I had TWO lb. amounts that Equaled each other depending if it was OFF the ground or ON the ground..... I also don't use the " approved " BRP method of measuring the oil, I only check it AFTER I ride for more than 10 minutes. .... I guess I'm just a " rebel " ........... Mike
    SoFlo
    Setting belt tension on the ground does work for you. You have experimented and determined your best on the ground setting.
    The maintenance manuals, accommodate the majority of owners, since most go to the dealership, and the dealer techs would not be able to contend with having owners in the shop as they tinker with optimizing belt tension for each owner.
    With that, they determined a tension that can be repeated each time the rear wheel is removed or tension is set.
    As we know, they did release a service bulletin regarding belt tension. Those that have reset to the lower belt tension spec range, following the maintenance manual method with weight off the rear wheel typically have had good results.
    As for you being a Rebel, living North of the Mason Dixon generally rules that out. Seems you are more like Doc from Back To The Future. Tinkering with something.
    SoFlo
    It could be better to have a loaded weight on wheels spec for belt tension. Unfortunately no tech would even be bothered setting to those requirements working flat rate pay.
    Jack the Spyder set the tension to a manufacturers spec, lower Spyder and done. In theory, this works for the majority of riders that are average size carrying average stuff in the frunk, trunk and side bags.
    All the best however you decide what works for you.
    Set ours to the median spec per the bulletin, using rear wheel off the ground, and essentially no vibration 99% of the time.
    Jul 2019
    Thank you for an explanation that even I can understand. I'll try the 160 lbs and see what happens.
    Jul 2019
    Well, I tried it at 160lbs and the vibration was gone at 72 MPH! But it vibrated like crazy at 44 MPH. Here's my theory- the belt is like a guitar string, the tighter it gets, the higher the frequency at which it vibrates. Lowering my tension merely lowered the frequency. As proof of my theory I raised the tension back up to 200lbs on the ground. Now it vibrates at 58-60 MPH. Sooooo, tomorrow I will install the tensioner (more like a vibration damper). I'll let everyone know my results.
    Aug 2007
    Greeneville, TN
    It takes awhile for the belt to settle into the new tension setting. More time the larger the change. I am not saying the vibration will go away. But you might want to give the belt some miles at a the current tension before making final judgement.
    Jul 2019
    Well, I installed the tensioner. What a CF! I think I used every tool in the garage and a trip to Harbor Freight. The bolts that came out of the frame tube to footboard bracket refused to go back into the holes they came out of. After about 4 hours I finally got all three bolts started and tight but I had to take the spring and roller arm off the tensioner bracket. then installed the arm, spring and roller after the bolts were in the correct holes and not cross-threaded.
    Now for the results- no vibration at 60 or 72 MPH, but I still have vibration at about 45. Second guessing myself, maybe it always did this and I'm paying more attention now. So my new plan is to just drive the thing and quit worrying about any minor vibration.
    Sep 2014
    USA
    Once a tensioner is installed isn't it recommended to lower the belt tension a bit??
    SoFlo
    Regarding the vibration at lower speeds, are you rolling on aftermarket automotive tires in the front and rear, or are you still rolling on the stock Kenda tires?
    Jul 2019
    Stock Kendas, only 4700 miles on it. BTW I just realized my Gravely zero turn lawn mower has Kenda tires!
