Page 2 of 2 FirstFirst 12
Results 26 to 26 of 26
  1. #26
    Active Member lugnut1009's Avatar
    Nov 2018
    Mississippi
    Quote Originally Posted by SportsterDoc View Post
    Yes, load is a factor in addition to RPMs.
    https://www.youtube.com/watch?v=uCEvBGT8twM
    I still do not see the need for a 82 HP motor to run 6,000 to 7,000 RPMs at highway cruising speed, when not accelerating.
    The Rkyer certainly is responsive, but 33 MPG cruising is not a plus point.
    Exactly. That’s why I think it would be as simple as replacing the spring in the secondary clutch with a softer spring. Primary is more or less tuned for the engine power band, secondary kind of sets the ‘gear ratio’ to the final drive. I know it’s not that simple, but that’s a simple explanation. Well at least until you get to full clutch shift. Hard to tell what we can do with cruising rpm without knowing what state the clutches are in at said speed. If primary is fully closed and secondary fully open, tuning won’t help at all. Maybe we just need taller tires? Ha
    Mine: 2016 Indian Springfield & 2021 Indian Roadmaster
    Wife: 2018 Can-am Spyder F3 Limited Pearl White
    2018 F3 Limited , Pearl White
