Results 1 to 4 of 4
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    Default 2019 F3-Limited - will Fox 1.5 Podium Shocks off 2015 work?
    I have a set of Fox Factory Series 1.5 podium off a 2015 F3-S will these work on the 2019 ??
    Thanks
    Last edited by Peter Aawen; 01-22-2021 at 08:53 PM. Reason: Fixed thread/duplicate
    Sep 2008
    TX
    Don't see any answer but I have a similar question for an F3-T. Looks like the frame and front suspension arms are the same part number. The shocks and springs are different part numbers from the "S" to the "T" models. I suspect that it has to do with the anticipate weight and riding style. The eye-to-eye distance should be the same. Somewhere I read what the dimension should be under load. I ride solo, so the front end weight should be similar between the "S" and "T" models. That stated, I'm going to try them, with probably a tweak on the preload adjustment to get the correct ride height. That and change to an RT front stabilizer bar (a.k.a. sway bar).
    pauly1 - SpyderDeb's 'wrench'
    2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
    IBA #48220 SS1000 BB1500
    2015 F3-S , OEM na Basic Black with Custom Wrap
    Sep 2009
    La Valle, WI
    They should fit. The S model uses different brand shock than the T&L models. Probably why part number is different.
    2018 F3 Limited , Oxford Blue
    Aug 2007
    Greeneville, TN
    Yes, they will work fine.
