VSS is a very sensitive beast.
Braking firmly from 50mph for a red light triggered the VSS.
When reversing, rear wheel rode up a slight curb, about 2”, triggered it.
I’m learning to drive more gently....
In both cases power off and power on cleared the warning.
Sensitive beast.
MWO (Ret'd) SJ Barnes
‘20 RTL Stone Grey
named Britannia in honour of EE Doc Smith’s
Grey Lensman’s ship.
Farkles:
Bestem Carplay
canamsypderaccessories hitch and wiring harness,
showchrome trunk rack,
12v AND dual USB direct to battery in the frunk,
dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
frunk lid organizer,
trunk organizer,
showchrome rider backrest,
ryder and passenger cup holders,
ram mount for the iPad mini I use for GPS
quadlock phone mount
Nautilus horn
Data blocker on the glove box USB
Big Bike Parts highway pegs
Spyderzone dash pouch
Convex mirrors
‘20 Ryker 900 (my wife’s ryde)
Farkles
Slingmods fwd/rev ‘suicide shifter’
frunk organizer
dual horn
Max mount
Rear seat with tall back rest (not mounted)
Ryder backrest (not mounted)
Side bag
Top bag
top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
There should be no reason to power off and power on for a VSS intervention. The light will come on for the 1 second or 2 while the VSS is active. Then go out. If that is not what is happening. Something is wrong and get it fixed.
2018 F3 LIMITED
Ok. I may be interpreting it wrongly. I’ll let it sit next time it pops up and see what happens. Thanks.
‘20 RTL Stone Grey
Farkles:
Bestem Carplay
trunk organizer,
Nautilus horn
Convex mirrors
Farkles
frunk organizer
dual horn
Max mount
Side bag
Top bag
Shouldn't even need to let it sit... just ride... as said above, if it doesn't go off after a couple seconds during the normal.course of riding, it needs to get checked out....
2017 Can Am Commander Limited
2012 Cadillac CTS-V Black Diamond
2020 F3 Limited Magma Red (miss the 2011 Viper red)
2010 RT622 - Black
Over the past 10 years I've triggered hundreds, of " VSS " events ( I don't think they are actual codes ) .... as said by Billy , it's usually a momentary thing, most of mine were to slight to actually cause a physical reaction to the Spyder ..... I don't advise looking at your instrument cluster for the " VSS flash ", this could cause an accident ..... good luck .... Mike
I agree, it is very sensitive. I was on a vacation approximately 600 miles from home, in mountainous terrain. I was in a downpour coming into a town, when all of a sudden my Spyder lost power, and the rear of my byke started swinging drastically. The byke straightened out, so I speeded up again when BANG, the same thing happened. I realized then that I had been hydroplaning. Long and short....IT IS very sensitive, but ONLY when needed, and thank the good Lord that it is.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Check the connector for the passenger seat detector. Maybe it's loose. If the passenger sensor is not connected the VSS light will stay lit, so I surmise if the connector is loose, or a wire is broken, then the VSS may be seeing the detector as connected, disconnected, connected, disconnected, and so on. It's conceivable to me that hard braking or quick climb up a curb could shake the wire and cause the connection to be momentarily broken.
2014 Copper RTS
