Results 1 to 4 of 4
    Nov 2015
    Southern California
    Default 2018 F3 Limited 5,000 miles leaking gas when filling it
    I’m at the D3WR in Deadwood and all of a sudden my F3 starts leaking gas when I fill it. The minute I stop filling it it stops leaking. Both times the Spyder was about half full and it leaks without it being topped off. Thoughts?
    Dec 2013
    Leaks from where?? Where is the gas coming from &/or ending up?
    It's not splashing outta the filler neck, is it??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Nov 2015
    Southern California
    It’s dripping directly below the tank on the ground. More on the right side. I’ll easily get a spot on the ground about a a foot in diameter.
    Sep 2017
    Durham,Maine
    Ive got no idea why, but if I was you I would hit a shop some where and have it checked out, loose gas flying around in the wrong places could be a bad day on the dusty trail!!! Good Luck
    2012 RTL , Pearl
