Results 1 to 5 of 5
    Pawleys Island SC
    Default fobo bike sensors will not sync
    I had an issue with 2 Fobo bike sensors. After reading the manual, I disabled both sensors figuring I could re-enable them when I figured out the problem. After checking out the pressure and installing new batteries, I attempted to resync them. No Luck. Any ideas on how to get them back operational?
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Did you take them back off and try to restart them
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Aug 2019
    Minnesota
    Quote Originally Posted by bikerjays View Post
    I also just now have one that will not sync with the app. It reads at 4 pounds. I have disabled and re-enabled. I have removed the battery and let it sit for a while and reinstalled the battery. I have tried a new battery.
    I will watch this thread to see if you have a solution. In the meantime I will write Fobo. I will report back with what I find.
    ba
    2019 F3-T Liquid Titanium
    “we are all products of those to whom we have chosen to listen”
    2019 F3T , titanium
    NorCal - Northbay
    Most likely a firmware issue. Especially if using an Android device. fYI, there is no option with the Android version of the app to update the firmware! Ask me how I know! Anyway, you will need an Apple product to do the firmware update. Anything that you can get the app installed on will work. It is a bit of a PITA but it solved the issue for me.
    Chuck
    Aug 2019
    Minnesota
    Quote Originally Posted by hypurone View Post
    The firmware failed with undetectable sensor.
    I sent a message to FOBO.
    ba
    2019 F3T , titanium
