Results 1 to 7 of 7
    Jul 2020
    New Hampshire
    Default 2012 RT - A/mkt Electrical item identification?
    Hello,
    I am new here and just purchased a 2012 RT Limited and it has an aftermarket item I am unable to identify.
    I have attached a picture.
    Anyone know what this is? It is attached in rear trunk and the wires are routed somewhere.
    Thanks for the assistance.
    Bill
    Mar 2015
    forrest above Reno, Nv
    Brake flasher??? Old style for sure.
    2014 RTS , Circuit Yellow
    Jul 2014
    Mint Hill, NC
    That looks like the brake flasher controller that used to be sold by Custom Dynamics. I have one on my Spyder and really like it. Rotate the knob and you can see how the flash pattern changes; select the one you like best. The strobe patterns are in the picture.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    Custom Dynamics. One of the best brake light flashers out there. I have purchased 6 or 7 of these over the years for various bikes.
    I am scared however to add anything to this bike because of the can-bus system.
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Idaho
    Quote Originally Posted by MrMagicFingers View Post
    No need to worry about the CANbus. There are no common non-BRP addons that you would put on that have any connection to the CANbus. In fact, I think the only BRP addons that have a CANbus connection are the CB and XM radios. All you have to do is be careful not to cut into any of the CANbus wires.
    Get a service manual. It should have a wiring diagram included. At least the ones for 2013 and later do. Go to www.canammanuals.com.
    2014 Copper RTS
    Apr 2020
    I have picked up a manual and it does have two wiring diagrams for the 2010 and 2011. It's the same one that you recommended above. Great manual. I haven't work a lot with CANbus and don't want to upset that Nanny thing. I come from the old school stuff where you don't have to worry about upsetting a computer and have your bike towed to the dealer. This is the first bike I think I have ever had that I am nervous to work on or add stuff to.
    Tim
    ___
    Idaho
    Tim
    If you look in the section for the controller area network there should be a diagram that shows what modules communicate with each other over the CANbus. The modules all have various power, signal, ground, and CANbus connections into them. Some, like the wires from the brake switch, are safe to tap into even though they go into the ECM. Another one are the turn signal wires from the cluster module to the turn signal lights as long as you don't tap into them with a wire that potentially could short to ground, like a trailer pigtail.
    2014 Copper RTS
