Results 1 to 8 of 8
    May 2016
    Okotoks,Alberta, Canada
    Default Looking for Signal toggle cap
    Hello everyone!!
    Just trailered my 15 RTS across Canada .. during the move somehow the directional signal toggle popped off . I’m looking to get a new one . Dealer says I have to replace the whole assembly @ $489 !! Anyone have any idea where I can find just the cap for the switch? It still works fine just need cap ...
    I didn't even know there was a cap to the switch but know the dealer is essentially correct about having to replace the entire left switch housing. Your best bet might be an individual or facility that is parting out a damaged/wrecked Spyder.
    Quote Originally Posted by Blackie312001 View Post
    Hello everyone!!
    Wow that s*cks ..... If you can't find it at ... cheapcycleparts.com .... and can't find the entire assembly from a salvage source ( cheap ) ... I would have one made. .... you might have to have a screw in the center to attach but it would work ..... good luck .... Mike ....... Is what's left able to work now ?????
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    I have a couple of spares. Email me at jerrytennant@charter.net with address and I will send it to you
    2014 RT SE6
    Apr 2020
    tucson az
    just a suggestion if you had a 3d printer you could try to print your own
    2011 rt , pearl white
    Quote Originally Posted by remus View Post
    I was going to suggest that .....however don't you need an original to make the copy ???? ..... Mike
    Jan 2019
    Kentucky
    Some used on Ebay. New they are really pricy. $429.99
    Apr 2020
    tucson az
    No you could use software to design your own. There are several different design software that you could download for free.
