Heated Pass. Handholds - are all F3's pre-wired?
Are the F3 series of spiders without heated passenger handholds wired to accepted the heated handholds?
Poasttown
Not sure about the F3 and F3S... but I know my wifes F3T is...
2017 Can Am Commander Limited
2012 Cadillac CTS-V Black Diamond
2020 F3 Limited Magma Red (miss the 2011 Viper red)
2010 RT622 - Black
Poasttown
I can't personally say the F-3 is " pre-wired ", but I would be very, very surprised if it wasn't ..... WHY ???? - Ford , GM, Chrysler etc. only make one " wiring Harness " for each separate model.... It's the only economical way to do it.... This makes building a car much simpler ..... I have found " capped wire harnesses " in my Basic model RT. The Basic doesn't have all the bells and whistles but the wiring is there if needed during assembly .... hope this helps .... Mike
The reason for my asking. If other spiders have the wiring in place, to add heated handholds, they must have some form of end cap on these plugs. If this is true then I would like to purchase these end caps so I can cover my electrical plugs due to me removing my electric handholds.
I’m currently using electrical tape which I’m sure is fine but this has become somewhat of a challenge. If and or when I get an answer I will post the info.
Poasttown
If it turns out that they are pre-wired I will be putting the set on my 2018 up for sale. They have to be removed for the OEM passenger armrests.
BKMNI
RWP!
2018 F3 Limited
Intense Red Pearl
2015 Harley Davidson
FLRT "Freewheeler"
Vivid Black
Pull the seat. It will have the 2 pin connector with a cap. Under the buttons by the key it will also have the connector for the control.
