2019 Spyder RT Limited with LED's & Hyperflash - any fixes?
I installed LEDs in the rear turn signals and now hyper flash. I tried the LaMonster thing, no go. Tried to hold the e flasher button down for 45 seconds, no go. Any suggestions? Is there a separate flasher for the rear turn signals?
Did you try it with the engine running?
For some reason that made the difference on my cousins when I installed the LEDs on his.
Held down Eflash button for roughly 30 sec, saw the dash lights flash once when the reset took place and all was good to go.
I didn't have the engine running, just the key on. Will try it.. Thanks...
After your 45 seconds are up, release flasher, turn on left or right turn signal for ONE FLASH and turn ignition off immediately. Same procedure on opposite side.
I have a 2018 RTL and when I put LED bulbs in rear turn signals I had the same problem. Went through all the e flasher procedures without luck. Has to put resisters in line to stop hyper flash.
Different companies now make LED bulbs with build in resisters...No splicing or soldering...
I like these...https://www.lasfit.com/
