Results 1 to 7 of 7
    Member Qt11's Avatar
    Jul 2020
    Kodak, Tn, USA
    Default 2019 Spyder RT Limited with LED's & Hyperflash - any fixes?
    I installed LEDs in the rear turn signals and now hyper flash. I tried the LaMonster thing, no go. Tried to hold the e flasher button down for 45 seconds, no go. Any suggestions? Is there a separate flasher for the rear turn signals?
    Jul 2015
    Dorr, michigan
    Did you try it with the engine running?
    For some reason that made the difference on my cousins when I installed the LEDs on his.
    Held down Eflash button for roughly 30 sec, saw the dash lights flash once when the reset took place and all was good to go.
    2020 RT Limited , Petrol Blue
    Jul 2020
    Kodak, Tn, USA
    I didn't have the engine running, just the key on. Will try it.. Thanks...
    Jul 2020
    Kodak, Tn, USA
    Didn't work.
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    After your 45 seconds are up, release flasher, turn on left or right turn signal for ONE FLASH and turn ignition off immediately. Same procedure on opposite side.
    Active Member KenF's Avatar
    May 2019
    Lacey, WA
    I have a 2018 RTL and when I put LED bulbs in rear turn signals I had the same problem. Went through all the e flasher procedures without luck. Has to put resisters in line to stop hyper flash.
    2020 Spyder RT Limited
    2020 RT Limited , Marsala Red/Chrome
    Mar 2008
    Hesston, PA
    Different companies now make LED bulbs with build in resisters...No splicing or soldering...
    I like these...https://www.lasfit.com/
