Results 1 to 19 of 19
    Apr 2020
    Pennsylvania
    Default Rotate front tires?
    New to CanAm...do I need to rotate the front tires?
    Danbury Connecticut
    It's a good idea if you could do it. The OEM Kendas are directional tires. The only way to rotate the tires is to remove them from the rims and re-install them on the opposite side.
    I dare say most don't go to that trouble.
    If you go to the dark side, it depends on which tire you've installed.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Feb 2020
    N. Wilkesboro, NC
    I have the auto rotate option. They rotate every time I ride.
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by MONK View Post
    Round and round and up and down they go!
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Quote Originally Posted by jimbombeck View Post
    I won't do the " cute " answer thing ..... From my own experience and reading from dozens of others like " SpyderAnn " who an alignment specialist ... .... If the tires you have MUST be removed from the wheel and flipped over and re-mounted AND re-balanced ... it's not even close to being cost effective, even if you own a Hydraulic tire remover ...... If you can swap left to right on same wheel, you MIGHT get another 2000 mi., but you would need to do the swap every 2000 miles for it to be effective .... In the past 11 yrs I have never done this to any Spyder ( 3 ) that I have owned ..... good luck .... Mike
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Mike is right.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Aug 2007
    Greeneville, TN
    I'm with Mike. The short of it is, it's not worth it. If you're alignment is good. They will go a very long time. If it's bad. Rotating them won't buy you much. Put your money into a good ROLO Laser Alignment. That will get you a lot more for a lot less than rotating the front tires.
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    The purpose of tire rotation is to even out (try to even out) wear.
    On 4 wheel vehicles, front to rear, rear to front, is the most important rotation.
    For example, if fronts are wearing on the edges due to cornering and rear are wearing center from spinning.
    If fronts are wearing inside edge or outside edge, then toe-in likely needs correcting.
    If both edges are wearing, tire pressure may be low.
    On a 4 wheel vehicle with a standard differential, the right rear may wear sooner from hard acceleration, so a right to left rotation is helpful.
    Center wear on drive tires may also be over-inflation.
    The moral of this story is that (a) tire pressure and (b) proper alignment are critical for tire life...and handling.
    If front tires are worn from an alignment issue, correct the alignment.
    If wear is bad, then align and replace the tires.
    Just my 2 cents.
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Aug 2019
    WI
    The bead material on modern tires will not survive being unmounted and remounted.
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    I do agree with Mike that it isn't worth the time. But my 2018 owners manual says you are supposed to rotate them by taking themon and off
    Quote Originally Posted by sgerksinwi View Post
    And here's why the owners Manual says that ..... BRP .... KNOWS ... the Kenda tires are just plain Crappy .... and will say anything to give you a bit more life, they also know they send out Spyders that are not properly aligned 75% of the time. ..... and further examination of ther " Owners Manual " will reveal that according to BRP , any issue with your Spyder should be checked by Your Dealer ASAP , by having it towed there !!! .... Do you see sort of a pattern here ????? ................ good luck .... Mike
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    Although to be fair, it isn't just BRP that wants you to take EVERYTHING to the dealer. It's pretty common advice across all the vehicle manuals I've ever owned.
    I read them but take much of what they say with a grain of salt, particularly the self-promotion stuff.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Nov 2018
    Denver, Colorado
    you don't need too. just answer
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    did a brake check and flush the other day. had the wheels off.
    got about 17000 miles on the famozas. swapped them side to side because
    i could. these things are wearing like iron ! not a lot of appreciable wear.
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    No!
    Aj
    new to canam...do i need to rotate the front tires?
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Apr 2020
    Pennsylvania
    Thanks... much appreciated!!!
    Feb 2020
    Austin
    Default Tire Rotating idea
    If you had the easy way to dismount the tires from the rims or take them to a local tire shop and get the remounted and balanced then it may not not be a bad idea to rotate them every 5000 or so miles depending on your driving. I see many people asking that question after the tire is already showing the metal thread inside but at that time it is too late and the tires are wasted. The alignment is obiously out of wack and the rotation idea is too little too late. Get new tires and do a proper aligment!
    2011 RT RStandard/5
    Wow, tires and oil in the same day.
    Let's post friendly. Many deep feelings on both subjects.
    On the rotation subject, my .02 is I will not waste my time on tire rotation.
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    I have almost 30,000 miles on my Hankook Ventus tires on the front of my Spyder. They still look almost new and have never been rotated. I should be able to get another 10,000 miles or so out of them. Of course I had my front end laser aligned many years ago.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
