Results 1 to 21 of 21
    May 2019
    New Mexico
    Default Found a good cleaning product to take when travelling
    I was mildly surprised when I was looking for an inexpensive detailer to clean up the bike a bit. I just washed it last week, but we had a spot of rain and I live on a dusty gravel road. I really don't like to waste my S-100 detailer unless the bike is fairly clean to begin with. I went with Rain-X waterless wash and water repellent. It actually worked quite well, even took care of a little bug-splat here and there.
    I went from debating whether it needed a complete regular wash or could I do this quickie wash, and by golly it worked. Did both the Rain-X waterless wash and the S-100 detailer in under 20 minutes, not bad. I'm thinking this would be great to pack on long travel trips - especially when you need to tidy up and drop the bugged-up look. These two and a little Novus (1) for the windshield and nobody's gonna know you just peeled off 500 miles... It's not a replacement for a proper wash, but it'll make you look like you did when on the road.
    Jun 2015
    Ritzville, Wa
    Thanks for the tip, I'll give it a look
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Feb 2012
    Spring City,Utah
    Where did you find the RainX dry wash?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2019
    New Mexico
    Against my better nature, I got it at Autozone. I could of saved a buck getting it a Target.
    Here's a link: https://www.target.com/p/rain-x-wate...B&gclsrc=aw.ds
    Sep 2017
    Durham,Maine
    I use Plexus on the whole bike, works well also!!
    2012 RTL , Pearl
    Sep 2014
    USA
    It's amazing what s clay bar can do to clean paint on vehicles. Bugs,tar etc comes off really easy along with things you dont see stuck to the surface.
    Aug 2019
    Stoughton, WI
    Local Walmart has it for $7/bottle. Will give it a shot.
    2022 RT Sea To Sky
    Mar 2019
    Fla/NJ
    i use Pledge spray, all surface cleaner Cheap and available everywhere
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    Another vote for Plexus!
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
    May 2019
    New Mexico
    Plexus is ok, it's just pricey at $26.00 13oz spray can
    So my tally is:
    $10 S-100 detailer and wax - 10oz spray can
    $ 7 Rain-X waterless wash - 32oz spray bottle
    $16 Novus 1 Plastic Clean and Shine - 64oz (super economy size refill for spray bottle)
    Yep, I'm a tight wad. At least, when it comes to cleaning products...because I hate spending money on branding...
    The Rain-X should be good for dozens of cleanups, I go through a can of detailer in about a year, and the novus plastic cleaner will last for years, so I'm feeling like there's good grubby money in my hands...
    Sep 2017
    Wa.
    I used Plexus on the whole Spyder including the black matte plastic too. Id buy it at the Cycle gear by the Spyder dealer in Vancover WA. an when going thru Auburn Wa at cycle gear. Ran out an went to auto zone an O Reilly neither had it so I bought Meguiars Ultimate Quick Wax in a spray bottle. Works pretty good an I use it on the black matte plastic too. Its easy spray on an wipe off.
    Feb 2012
    Spring City,Utah
    I use Yamaha Spray Detailer. I think it is 7.95 a can and one can lasts me for at least a year. Yamaha dealers are everywhere. It can be used on every part of your Spyder and leaves it clean and shiny and doesn't attract bees like the Pledge. My windshield is 8 years old and has 58,000+ mikes on it and no sign of crazing "sparklies" .
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Oct 2016
    Sebring, FL
    RainX might be worth shot at Walmart, I have fear of getting those 'minute' hair line scratches you can see when the sun is right using a detailer product without some water as a buffer but maybe I'm wrong? I'm like to try it when I'm on a trip and water is not available.
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    Can our tupper ware withstand a clay bar treatment??????
    Sep 2014
    USA
    Yes I used a mild grey bar type and plenty of lubricant or even car wash with lots of suds.
    I dont find it abrasive at all and it used a little piece of the bar at s time. Did my whole truck with a small chunk of the bar.
    Jan 2016
    Newport, Oregon
    I too use RainX and have found it works well on the bike as well as the windshield. Takes the bugs off and leaves absolutely no streaks. At $7.00 / gallon @ Walmart it is very affordable. Good product.
    "Don't run TO the finish line. Run THROUGH the finish line!"
    2010 Spyder RT-S SE5
    ISCI Handbrake
    Seal DLX Floorboards
    Trunk Rack
    Feb 2020
    Albuquerque, NM
    Quote Originally Posted by honsfun View Post
    Yup, same here, clean the entire bike with it, have not put a drop of water on it since I bought it 3 months ago. Used in on my previous bikes, airplane canopies, etc. Cheap, works like Plex, plus it smells good and leaves a nice light coat of wax on the windshield, which helps keep it clean.
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    When I bought my current Spyder (used) it had a lot of hard water spots on it. I tried Meguiar's Clay Bar Kit - gray clay plus detailer spray and a microfiber cloth - and it helped smooth the surface but did not remove the calcium. I agree it doesn't seem abrasive providing the clay doesn't get full of grit lifted from the surface.
    The only thing I found that fully removed the water spots was Griot's Garage Correcting Cream. It seems to be minimally abrasive as long as you don't rub too hard. The paint and Tupperware survived in excellent shape. All I needed after that was a good coat of wax. I've become a Griot's fan after that experiment.
    To answer the original question, I've had very good luck with Harley-Davidson Quick Wash and their Gloss Detailer. Both products can be used on all surfaces, from paint to chrome to vinyl and leather. Not exactly cheap but great results.
    Before and after Griot's:
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    May 2019
    New Mexico
    Quote Originally Posted by RideOn View Post
    Gads - over here our water goes up to 44gpg/700+ppm hardness. It is absolutely *required* to rinse with deionized "spot-free" water - otherwise it's spot city in just one wash.
    Sep 2018
    Bakersfield, CA
    Quote Originally Posted by SuperG View Post
    Yes I figure that's how the spots got on there originally. Central Valley California water is sometimes called "liquid rock" because it's so hard.
    2014 Spyder ST SE5
    Jun 2015
    Ritzville, Wa
    I think I paid $6.34 at Walmart
    Greg Kamer
