Originally Posted by Crewless
no one there is capable of fixing the problem.
Highly likely.
I have no trust/faith in my local dealer(s) after seeing some of the results of dealer visits my riding friends have had.
Originally Posted by mecsw500
I bought a new 2021 Spyder RT Limited a few months ago.
Threw code C210A for the rear suspension on the way home.
Went back a few times, they discovered the rear linkage was not connected during the PDI.
Threw the code again on the way home.
Took it back, they replaced the rear ride height sensor.
Took it back, they found the Schrader valve leaking.
Took it back, they found an air leak.
Awaiting news as to what BRP say they are going to do next.
Only happens when I'm on the freeway at over 65 mph. Doesn't happen, even 2 up, on surface streets or in the canyons even. Doesn't happen for the dealer's tech as I assume he is lighter than my 240 lbs.
I'll call them again tomorrow. I'm a really mellow person and quite tolerant of what appears to be a difficult problem to solve, but even I am getting tired of the round trips to the dealer.
I guess the only things left are BUDS setting the correct height parameters, which I hope they would have checked by now, the compressor, or some lack of reliable communications with the suspension sensors to the main computer. I tend to rule out the latter due to the circumstances that cause it to throw a code, but you never know.
So, anybody have any ideas. I'm at a loss and wanting it to get fixed before the snow comes.
Well I took it back the next week and it has been at dealers ever since, like 6 weeks now. With the bad weather I guess it's been hard to get it out on the road, but I'm beginning to wonder if I'll ever see it again. It's go to the point it has now been at the dealers for over half the time I've owned it. If it doesn't get fixed soon after the weather improves, I'm going to ask they replace it with another one.
Can Am Syder RT Limited (2021)
Triumph Bonneville T120 (2018)
Master Tech
Originally Posted by packerfan
You might want to take a look at this video. Sounds like a similar problem and this guy is a master Spyder tech.
https://youtu.be/K1rL8R-WHl0
I'm having the same problem. I would love to know were the Master Spyder tech is located.
What year bike do you have? If it's new get it back to any shop and let BRP pay for it!! Stupid air ride system, great thing when it works, pain in the back in more ways than one when it doesn't!
Reason: get thing... ;-)
I love the bike. It's been in the shop three times for this issue.
The master tech from the video is in Vancouver.
Chip
2020 RTL
"Stella by Starlight"
