Results 1 to 9 of 9
    Jun 2020
    Rogers, AR
    Default What am I looking at on my 2015 F3
    There is a box mounted on the left side of my F3 that I believe is an add on. The first pic is the box from the outside, the second is the end of it showing what looks like two audio ports, and the third is a toggle switch by the air filter box. Any ideas what this is?
    Larry 2015 Spyder F3 SM6
    2015 F3 SM6 , Orange
    Dec 2013
    It certainly looks like an add-on?! As to what is it?? Maybe it's a power amp of some sort?? Possibly music type amp, or maybe it's a piggy-back 'power commander' type chip for the ECU, hence the toggle switch to enable/disable it? I've seen similar looking 'Power Chips' for hi-tech DI Diesel engines, but I don't think any of them had the 2 'audio ports' on their ends?!
    Can you see where any of those wires come from/go to?? What's the toggle switch wiring connected to??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jul 2019
    AL
    looks like after market amp
    Jun 2020
    Rogers, AR
    I was leaning towards an amp for the speakers which I will be removing. I got to thinking about that after I created this post. I'll be working on that tomorrow. I might try mounting some kind of radio later. Neither of us have any music on our phones, which the speakers are set up to use. I'll let you know what I come up with tomorrow.
    Bossier LoUiSiAna
    Before you startDocument everything ! plenty of pics & notes, what wires spliced together ( use some number tape if necessary) , any other things you may notice in the process if it is tied to ECM you may Find a need to put it back Those ports could be for sensors Of some sort. Hopefully it is just an audio contraption, worth contacting the previous owner with late questions.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2017
    Durham,Maine
    Trace the wires and see where they go!! That would be the first thing I would do, just in case it is a mod of some sort!! Good luck
    2012 RTL , Pearl
    Jul 2020
    NE Oklahoma
    Flux capacitor. Don't touch it!
    Kid Doc
    2019 F3-T
    All states and provinces visited solo on 2 wheels since 2006!
    Mar 2015
    Indianapolis, IN
    I was going to ask it it had speakers on it - you said yes. That's totally the amp. You should find the speaker wires running to it and the power lines from the amp running to the battery or accessory line. Haven't seen anyone stash one there before - but that's what it is.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Jun 2020
    Rogers, AR
    Yes, it was a Boss Rebel amp. There was also a usb port. Neither was tied to electric. I removed them. I ended up cutting the lines to the speakers, but they can be easily rejoined. I would have asked the po, but don't know him, never met him. He traded it in on a motorcycle, and I bought it from the dealer. After I get the wiring put back together, I'll probably put it up for sale after I research it some.
