Results 1 to 7 of 7
    Mar 2020
    Yale, Michigan
    Default air bubbles in engine oil
    I looked for an answer and didn't find one so here is my Question. Checking the oil level- run engine till at operating temp- let idle at least 1 minute (it says 30 seconds on the tank)- turn off engine- remove dipstick notice oil is full of bubbles not foam just bubbles, wipe stick notice oil level is dropping fast in tank , quickly check level is ok , is the bubble and level dropping normal?
    Which year/model & engine would help, altho generally, LOTS of bubbles in the oil is not a great sign...
    Oct 2014
    Fort Mill, SC
    This is a dry sump engine. The oil is continuously pump through the system and picks up air along the way. Normal.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    I've never seen bubbles on my Spyder dipstick.
    Mar 2020
    Yale, Michigan
    its a 2010 rt . The dealer changed the oil b4 i bought it. So I really don't know what oil they used. But it looks clean.
    Jul 2011
    Mitchell, Ontario, Canada
    Normal for the 998 engine. As mentioned above. Dry sump pumps suck a lot of air with the oil. Wait for just a minute and the bubbles will be gone.
    Some oils foam more than others. Generally, it isn't a big problem. The only place foam will hurt you is if it happens between 2 moving surfaces. Air does not lubricate at all and you'll get scuffing and wear.
    BRP uses Castrol products. They are known to foam more then most. Just a characteristic of that product. If you use the BRP (Castrol) oil, you will need to wait longer for the foam to dissipate as it will give you a reading higher on the dip stick than it should be. If you are using another product. You may not notice any foaming at all.
