Results 1 to 7 of 7
    Active Member triplethreat's Avatar
    Feb 2020
    "Murvil", TN
    Default Interesting Article about Cornering....Basic Stuff, but Good Info...
    So here is a link from Motorcyclist Magazine if anyone cares to look through and read it. It's about 4-5 minutes of your time...
    https://www.motorcyclistonline.com/h...orSBoGZH-qfNJp
    Thanks for the post. Another great read on riding the twisties.
    May 2016
    Tombstone Az
    Well there are some that will disagree with that concept and argue that delayed entry is better method.
    https://youtu.be/RQ0Z5FfxxBE
    Quote Originally Posted by triplethreat View Post
    Thanks .... good info , but remember they are using a TWO wheeler. Spyders are really closer to CARS then Mtc's ..... jmho ... Mike
    Feb 2020
    "Murvil", TN
    Quote Originally Posted by Beaudog View Post
    HUH....did you even read the article? Maybe need to check it out again!
    Feb 2020
    "Murvil", TN
    I understand that the article is about two wheels, but the very same concept can and should be applied to three wheels....a.k.a. the Spyders. Granted, on a Spyder you don't have as much room for moving around the "lane" as a two wheeler, but the concept is exactly the same results....you are "straightening" out the corner....just not quite as much as with two wheels.
    Basically, I agreed with you, and in an earlier post I did ( maybe on the other thread ) I said I do what was said in the LINKED article .........Mike ....
