Results 1 to 18 of 18
    Dec 2018
    Albert Lea, MN
    Default Kenda Kanines 3k review
    This spring I had my dealer install three Kenda Kanines on my 2018 F3L. I had @ 6000 miles on the OEM tires. Was not happy with the wet weather performance of them. I had the idler pully installed and still had a ton of vibration . So much that at 50+ MPH I could not see google maps on my iPhone that was mounted to my handlebars.
    So my observations of the Kenda Kanines:
    1. Vibration from front tires is completely gone. I can not even come close to describing how much better the ride quality is of these tires.
    2. I had to ride in some nasty rain early this week. Significant improvement shedding water. Never felt ant any time that I was close to hydroplaning. Really stick to the road.
    3. Wear. Completely even. They still look new after @3k miles.
    I am completely satisfied with these. It will be awhile until I know how many miles I will get out of them But I expect that they will be better than the OEM tires. Oh, they cost less than the OEM tires too.
    2018 F3 Limited Dark , Stock Intense Red Pearl
    May 2018
    millsboro,delaware
    I leaving on a several thousand mile trip sunday and will report on my feelings about my new k20 rear tire.
    : 2017 RTL ORBITAL BLUE
    I am also watching this one with interest. I am good for several thousand miles, new tires on both vehicles, one darkside set and one OEM Kenda set.
    When it comes time again...
    Sep 2014
    USA
    Now I dont have all three Kanines but do have the rear and noticed a much better smoother feel ride compared to my Automotive tire. I didn't balance the rear , just used Counteract beads.
    As mentioned more riding time will be able to give better details on how the Kanines work out.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by KenInMN View Post
    What pressures are you using?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    I did purchase the Kenda Kanines rear tire, what is the going price to install the new tire at the dealer I would be supplying the tire?
    richie spyder
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by ssmcclub View Post
    I don’t believe that there is a “standard” price. All shops have different “shop rates”. Call your dealer and ask them.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by bigbadbrucie View Post
    And when you do cal them make sure your sitting down.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Active Member TheCajun1957's Avatar
    Kilgore Tx.
    KenInMN or someone who has them mounted, could you do me a small favor, measure how tall the front Kanines are from the ground to the top of the tread. Thank you in advance!
    2018 White F3 Limited
    Sep 2014
    USA
    Quote Originally Posted by TheCajun1957 View Post
    Does the specs help you any??
    https://powersports.kendatire.com/en...street/kanine/
    Kilgore Tx.
    I'm thinking the spec sheet is with the tire not mounted. That's why I was asking if someone would measure it on the Spyder. It will be interesting to see what the difference is. SPECS say its 23 inches outside diameter.
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    $150.00 an hour from my dealer
    Jun 2020
    Hillsborough,NH
    Ouch.. my dealer is $99 still ouch but better than 150
    Adrian, Mi
    I'm getting the Kanine front tires next Friday, just changed the back last year it'll have to wait. Only got 25,000 on the original fronts (yep amazes me too) 16,000 on the original rear might have pushed that one a bit. Happy to hear the Kanine's are wearing well.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Tell us when you get 40000miles on them if they last that long
    May 2016
    Find someone else that’s way to high
    Dec 2018
    Albert Lea, MN
    15 up front, 28 in the rear
    Aug 2019
    Stoughton, WI
    Local shops in my area charge $200
    2022 RT Sea To Sky
