Results 1 to 21 of 21
Thread: mirror covers
    Oct 2013
    rome new york
    Default mirror covers
    Has anyone had an issue with the front covers on the mirrors coming off from wind??
    TIA
    Jul 2010
    Las Vegas, NV
    Last year, at Deadwood, a guy rolls up on a brand new 2019 F3LTD. He was so proud! He brought it over for an alignment, and to show it off. It was beautiful, except one small detail:
    Both mirror covers were gone! We made it a point to check every one that came in our booth. Most were ready to make a break for it! Check them often, and put a small piece of clear Gorilla tape on the underside. If it does fall, the tape will hold it long enough for you to notice it!
    Joe Meyer
    Jun 2010
    Las Vegas
    When they took the turn signals off the mirrors in 19 the solid covers didn’t seem to fit and, as Joe said, they tend to fall off.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    So far so good on my 2020. I checked them when I put my wedgies in tonight and they clip in fairly strong. Time will tell. Maybe they improved them a bit this year, but doubtful...
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
    Danbury Connecticut
    Interesting. I wonder if the dreaded mirror shake puts strain on the locking tabs....................
    One of my mirrors shakes pretty bad, the other doesn't.
    I haven't figured that out yet either.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    mind has came off 2 times .when i first got and yesterday.
    2019 f3t , titanium
    Mar 2017
    I hit an amazing bump/hole on a dirt road and heard something hit the ground. Got home and one of the covers was gone. I thought, I'll just order another one. OVER $100! Following day, went back to the scene of the crime and found it. Only had some scratches on the bottom. Still running it today. I got a set of Baker wings which come with a bracket & screws. It won't come off again!
    May 2020
    Quinton, VA
    Last night on I-85 in VA, old concrete road, I hit a grapefruit sized concrete chunk. Both covers popped off. Found them this AM. The covers will need painting, since they went flying at 75mph. Oh, the right wheel was bent & rim cracked some 60 degrees, as in cracked enough to stick a popsickle stick through.
    Apr 2016
    St. Charles IL
    BOTH of my mirror covers fell off today! Found one. It's pretty beat up. Don't know where the other one went. Does anyone know if BRP is replacing them under warranty? The machineF3 LTD with 2,800 miles. I suppose it depends how the dealer writes it up...
    Bill W
    2019 F3 LTD
    Aug 2019
    upstate NY
    the dealer replace mind on charge
    2019 f3t , titanium
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    I hit a substantial pothole, the left cover came off and could not be found. The right mirror and cover came off completely, however the wires kept it connected to the bike. The bike is under warranty but the dealer stated that is was not covered. $120 for the cover and 1/2 hour labor at $50. I put a clear piece of gorilla tape along the bottom to hold them on should this happen again
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Danbury Connecticut
    Since this thread started, I've made two improvements.
    First, I used Lamont's technique to minimize the mirror shake. This will hopefully eliminate the source of the covers coming off.
    Second, I installed Spyder Pops Vision Kit. This includes two run/turn signal lights at the mirrors.
    I chose to install the LED light strip on the front of the mirror to mimic the old turn signals.
    The wiring to the LED light will act as a lanyard if anything should happen.
    IBA #47122
    Apr 2016
    St. Charles IL
    Quote Originally Posted by pieman9155 View Post
    Did you mean "NO" charge??
    Bill W
    2019 F3 LTD
    Jan 2019
    Euclid, Ohio
    Both of my mirror covers have come off. I recovered the right and had to go on Ebay to replace the left. I glued mine on which I may regret one day when the bulbs need replaced. But in northeast Ohio the highway expansion joints are so severe that gluing them on gives me peace. The BRP clips are crap. I almost lost one of my F3T's rear speaker grills also. With the speaker grill I was able to secure with a screw. The screw can only be seen when opening the trunk lid. I spent 80 bucks for the used mirror cover. I can only imagine what a speaker grill/cover would cost.
    Sep 2009
    La Valle, WI
    I put Baker built hand wings on under mirror. Solves problem since you drill thru the cover and add a bracket that holds the cover on.
    2018 F3 Limited , Oxford Blue
    Jun 2020
    Maryland
    I am a new owner of a 2019 limited, what covers are you talking about and what should I be keeping an eye on
    thanks
    Aug 2019
    upstate NY
    yes
    i still have the old one
    2019 f3t , titanium
    indpls in
    i put a dab of silicone on the mounting points no more issue
    Mar 2017
    Quote Originally Posted by Mcolabella View Post
    thanks
    #52 in the fiche.
    Jun 2020
    Maryland
    Quote Originally Posted by Rattlebars View Post
    #52 in the fiche.
    Thanks,
    but wow design flaw???
    Danbury Connecticut
    If the clips seem loose, you can bend them outwards a little bit to make a tighter fit.
    IBA #47122
