Results 1 to 10 of 10
    Aug 2016
    Calverton N.Y.
    Default Exhaust - can I keep the OEM Muffler with a Cat delete pipe?
    I have a question about the cat delete pipe. Can I keep the OEM muffler with this pipe or do I have to change the muffler as well?
    Dec 2013
    You sure can!! Some even argue that it sounds and works 'best' this way!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    .... If you add the " Baffle " it will change a bit .... on 1330 RT I tried it with and without ..... I decided to keep the Baffle ..... IMHO the CAT delete will effect the weight and sound .... not performance .... Mike
    Dec 2016
    Gold Coast, Australia
    Agree with Peter. Sounds magic with cat delete and stock muffler. Had Jases ECU upgrade as well.
    Tip: get the cat delete pipe ceramic coated inside and outside, reduces heat by a long way.
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Is there any where you can still find a cat delete for a 998?
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
    Jan 2018
    North Carolina
    Options from RLS for a 2013 rt-s sm5....
    Exhaust @$325....cat bypass @425...
    Any experienced opinions on the best option?
    May 2014
    Cornish, Maine
    Tatonka, did you make a change? I'm looking into doing the same cat delete with RLS pipe. if so, how did it go and do you like it?
    May 2014
    Cornish, Maine
    Rawspyder, did you make the change? do you like it? I'm thinking I want to do it as well.
    Jan 2018
    North Carolina
    Yes, did the cat delete and installed a triple slip on exhaust made for the 998 by www.spyder1attude.com
    Much lighter and louder
