Scuff marks on tank
2020 RTL- I accidentally put a double scuff mark on my tank on the top coat. I believe it was done with the rubber sole on my boot as I was getting on or off the byke. I researched prior threads and it appears most on this subject are somewhat dated. I tried Lamonster Black Dymond Detailer that was suggested, but it had no effect. Looking for any updated suggestions? Thanks in advance.
Try scratch doctor by nu finish. It's a mild rubbing compound. Works good.
Scuffs
Any Auto polishing compound should work .... Mike
I have had several scuff marks on the lower Tupperware side panels from my boots and plain old liquid auto polish/wax has removed them. No damage to top coat.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Worst come to worst--I cautiously use Acetone , be quick--put on rag--wipe off the mark. then use auto polish. I've used it many times on several vehicles & never damaged the paint. Finger nail polish remover works also.(it contains acetone)
formerly pman2011
I use my passenger foot pegs to get on and off my F3 to avoid scuffing the tank.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
The paint on ALL Spyders is water-based ..... I'd be EXTREMELY careful with Acetone ..... jmho .... Mike
