Results 1 to 12 of 12
    Nov 2019
    Kansas
    Default Glove box lid removal - is it easy to do? Any tips on how?
    I need to removal the glove box lid to install a carbon fiber covering on it. Is this easy to do?
    If not, my other option is removing my windshield. But was hoping the lid removal is easier. :-)
    Quote Originally Posted by acdcking12 View Post
    Last I remember quite a bit of tupperware has to come off to remove the two piece assembly ..... but you probably noticed the part with the arms is separate from the cover ..... I just tried mine and I couldn't get them to separate ..... find a Fiche' that shows this assembly maybe that will help ..... Mike
    Mar 2017
    IMHO removing the shield would be WAAAY easier. I just went through that because I wanted to put non-reflective cloth so I could run my GoPro from the dash without seeing the reflections on my shield from that cover.
    Feb 2020
    N. Wilkesboro, NC
    Pair of channel locks would probably work.
    Member Hoodrich13's Avatar
    Jul 2019
    NC
    Default Help if you can - how can I remove the glovebox door?
    Currently tearing down both 2021 F3Ls for paint during the off season.
    What i can't seem to figure out is how to remove the glove box door. If anybody can help me not break it, it would be greatly appreciated.
    Keep your wheels down and your head up
    Be safe and ride hard
    2021 F3L , Black (for now)
    Jul 2019
    NC
    Im dealing with the same issue. Took the windscreen off. And all the plastics. Its the last piece to get it to paint. Has anybody taken it off ? Anybody willing to give a word of advise ? Thanx in advance
    Quote Originally Posted by Hoodrich13 View Post
    I suggest you look at a "parts" Fiche' ..... try cheapcycleparts.com .... they should have one for your year and model .... it will show you all the parts and how they fit together.... good luck .... Mike
    Jul 2019
    NC
    None that i found (cheapcycle parts) show how it is attached. Any other ideas ? I would hate to break it and have to wait months for it to show up.
    Mar 2017
    Separate part #.
    Active Member Spyder Hawk's Avatar
    Feb 2015
    California
    Hoodrich13 did you ever get the door off? I'm trying to get mine off too and I can't seem to figure it out.
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    Quote Originally Posted by Spyder Hawk View Post
    It's been a while ... but I remember taking the glove box lid off my F3 Ltd in order to route a phone cord (needed to cut a couple of strategically placed notches). As I recall, I did so by removing the windshield first as this gives you room to "fully rotate" the lid and reveal that the "side arms" press slightly in (or out, not positive). Once the side arms are free from the housing, the lid should just rotate to a small slot and lift right out. Going to go look at my maintenance manual, pretty sure that is where I found the technique.
    UPDATE: Attaching screen capture from the maintenance manual .... memory is close; you do have to remove the windshield in order to get to the tabs and fully rotate the lid to remove. See attached for details.GloveBoxLidRemoval.jpg
    Stay tuned ... I may be back with an update.
    Last edited by Spyder_Cowgirl; 01-12-2022 at 04:00 PM. Reason: Adding Instructions from Maintenance Manual
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
    Nov 2020
    Lincoln, Nebraska
    Tape it off and do it on the trike.
