Results 1 to 9 of 9
    Active Member sledman's Avatar
    Nov 2016
    Idaho
    Default RLS Cat Delete - Polished
    As new, used approximately 400 miles on my 2019 RTL. Comes in origional box/packing with spring tool. $210.00 plus actual shipping.
    Jan 2019
    SW Georgia
    Pm sent
    Nov 2016
    Idaho
    Jan 2019
    SW Georgia
    I will take it
    Jun 2016
    indpls in
    youll like it
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    I'm wondering what the advantage is of a "Cat Delete" system(??) Does it make my RLS "Torpedo" muffler louder? Will it cause "error" codes ? Would I have to reprogram the fuel system?? thanks in advance for any explanations out there.
    Aug 2019
    Stoughton, WI
    A.) Less heat from the cat converter
    B.) About 15# weight savings
    C.) Better (subjective) sound
    I find my cat delete/stock muffler sounds good. Deeper bark/not too loud. Gotta believe a cat delete + aftermarket exhaust would be too loud for me, but again, personal opinion.
    Just a cat delete will be fine with a stock muffler. Cat delete + aftermarket exhaust could push the A/F to the leaner side of things. Always will run better with a DJ PV3 or ECU flash, but don't want to hijack any further...
    2022 RT Sea To Sky
    Mar 2020
    Martinez, CA
    Jan 2019
    SW Georgia
    Quote Originally Posted by redrazor View Post
    If you have the ecm remapped, removing the cat is like opening the lid on a new can of giddyup-n-go on the 1330. I have the straight pipe cat delete with OEM exhaust and it’s a bit too raspy. Hoping this rls will mellow the sound out a little.
