Results 1 to 16 of 16
    Jun 2020
    AZ
    Default Oil Change - anyone used dip-stick pump/sucker?
    I am coming up on my first oil change on my 2020 RT Limited.
    Has anyone found a way to remove/pump the oil out of the dipstick tube to avoid the hassle of raising the bike?
    Dwight
    Last edited by Peter Aawen; 06-27-2020 at 06:43 PM. Reason: This is a 'How do I?' not a 'How to:' diy explanation....
    This question has come up previously. You are probably not going to like some of the replies.
    Put on the asbestos vest.
    There may also be some good ideas.
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    To make a long story short, follow the manual.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Jul 2014
    Mint Hill, NC
    If you want to try, go ahead and waste your time; you won't be able to get all the oil out without pulling the crankcase and clutch cover plugs. Don't insult your new investment by attempting a sh***y maintenance procedure.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Idaho
    The design of the 1330 engine won't allow any kind of tube to reach the bottom of the oil reservoir. The only way to remove all the oil is to use the drain plugs per the manual.
    2014 Copper RTS
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    how much harder is it to do an oil and filter change on the 2020 than
    the earlier 1330 rt's? or not ?
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Nov 2012
    North Las Vegas, NV
    It won't work, don't waste your time. It's not a wet sump system. Why not have Joe and Ann do it. Why is this asked every month?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Aug 2019
    Stoughton, WI
    Besides, suctioning would never remove all of the build up crud/wear metals. Just do it the correct way, as the flowing oil will act as a particle flush..
    2022 RT Sea To Sky
    Jun 2011
    Near Lexington, NC
    Suctioning/vacuuming is being widely used by car dealers; however, as noted above, a tube will not reach the bottom of the 1330, thus leaving some old oil behind.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    You might want to read my post here: https://www.spyderlovers.com/forums/...Change-Warning
    2020 RT Limited , Marsala Red
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Active Member WDAVEY's Avatar
    Jul 2019
    FL in winter, CNY in summer
    My concern has to do with protecting your warranty. Who is doing your "3,000 mile checkup"? Will you dealer honor your warranty if something happens at 7,500 miles? On my 2019 I felt it was prudent to pay the dealer to change the oil and do the checkup. At the same time I had the laser alignment done. Total bill at Florida Motorsports in Naples Fl was $536. Not cheap, but reasonable to protect a $27,000 machine. BTW, the laser alignment was $150 and was worth every penny. I also installed the Bajaron sway bar and my spyder is no longer "twitchy".
    Dec 2014
    S.E. Michigan
    I use a suction apparatus intended to siphon gas. I'm guessing maybe half the oil comes out. Then i continue with the real oil change. Somewhat less messy that way. YMMV.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Feb 2020
    Austin
    "Not cheap, but reasonable to protect a $30,000 machine." Enough said.
    Jul 2010
    Las Vegas, NV
    Dwight,
    Bring it to me, I’ll walk you through it. Raising it is pretty easy. Just call me. I’m doing 2 this week!!
    Joe Meyer
    Jun 2020
    AZ
    Thanks for all the input. I will be following recommended procedures.
    Dwight
