Results 1 to 7 of 7
    Default TO THOSE WHO HAVE THE Quatrac-5 REAR TIRE
    Please help everyone who might buy this tire. .... could post here the mileage you have on this tire ( also the tire size and the model of Spyder ) ...... I began recommending it about 6 mos. ago .... it's wet / dry performance rating is very high ... however it's not known how long it will last ..... so lets post the numbers ..... THANKS VERY MUCH ......Mike
    Aug 2019
    southwest oHIo
    Only have a few hundred miles so far on the 205/65, but it might be a good point to note that it started with 10/32" of tread.
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    I have around 1000 miles on mine (all three). The first weekend I put them on I rode about 4 hours in pouring rain, on various types of road surfaces and at variable speeds. Never broke traction nor did i feel like I made a bad decision. As far as wear, with only a thousand miles hard to tell but still looks as if I just put it on. I have not checked the depth and probably won't I'll ride them to they tell me the need to be replaced.
    To be continued....
    Apr 2012
    Florida
    Only have 5,000 on mine. They still look new. Tom
    2020 Petrol Blue Metallic RTL
    Active Member Abbot Spyder's Avatar
    Jul 2008
    Abbot Maine
    I have a 2016 RTS special series. I put Quatrac 5 on all three wheels. I have around 12,000 miles on those tires now. I have 17,000 miles on the Spyder. No issue on dry or wet pavement. The front tires are still in very good condition. There is no cupping and they wear evenly. The back tire is 205-65-15 has 3/32 thread left in the middle groove and about 5/32 on the outside grooves. I started with 20 psi than I went down to 19 psi and now 18 psi. I try 16 psi and 17 psi and it felt loose. So 18 psi seems to be the sweet spot riding 2 up. My next tire will be Altimax.
    IBA # 61125
    Saddle Sore 1000
    Bun Burner 1500
    1st one to do 48/10 on a Spyder
    4 Corner Finisher
    SCMA Member
    Quote Originally Posted by Abbot Spyder View Post
    Yes I agree 18 may be best .... another member here has the same set-up as you He and His pass. total almost 400 lbs. ... He has 18psi in the rear and has very even tire wear ...... Mike
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    I have 205/60R-15 on the rear of our 2014RTL. 10,353 miles on it today. Running 17/18 PSI.
    On 05/15/20 I had 8280 miles on it, and read 7/6/7 (32") across the tread.
    On 05/15/20 I had 8654 on theQ-5 fronts (175/55R-15) and I read 8/9/8 on both fronts. I run 15/16 PSI on those.
    ALWAYS 2 up.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
