Results 1 to 6 of 6
Hybrid View
    Active Member DaveMcC's Avatar
    Hamilton, Montana
    Default Missing Zumo Charging cord
    Just purchased a used 2017 RT LTD. Traded in my 2013 ST LTD. The RT came with the Zumo Garmin GPS but no connector for getting updates from Garmin. Do I go to Garmin and buy the proper cable or is there an alternative?
    Danbury Connecticut
    This should do the trick for you!
    https://www.amazon.com/UGREEN-Chargi...ef_=ast_slp_dp
    Surprisingly, even the new XT, in the age of USB C still uses that same cable.
    IBA #47122
    2020 RT Limited Asphalt Grey
    If you have a Zumo 590, which I think you should have if tie previous owner got it with his RT-Ltd, that cable in the Amazon link is not the one you need; the mini end is the wrong type. You need one that looks like this.
    Aug 2019
    Stoughton, WI
    Any mini usb will work for data transfer.
    2022 RT Sea To Sky
    Hamilton, Montana
    Ordered the one from Amazon. ~$6 is not a bad price even if it's wrong. I suspect the cord from my old Nuvi GPS will work if all else fails. Thanks, guys and gals.
    The Nuvi cord will work. That Amazon link one will not fit in the Zumo.
