Is there a Trans filter change video for 2014 and up RT's?
doc humphreys had one years ago but it was taken off. cant find a video of an rt transmission filter
change . want to do one next oil change. are there any out there ? thank you !! irv
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
If you can change your own oil and filter you can easily change the HCM filter with no video needed. The only very minor thing I faced was getting a Torx bit on Bolt #4, lower, rearwardmost one in the tightening sequence picture; just had to loosen a little more Tupperware, no big deal.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
I changed ours when I did the oil change closest to the 30,000 mile mark. I took my time and let the case drain overnight, and cleaned the ports and sealing surfaces and lightly oiled the rubber oring that the HCM filter port has that engages the case.
Then just use the cross sequence to even out the 6 cap screws up to about 5 INCH pounds torque, and then go over the sequence again to bring them up close to the prescribed 9 INCH pounds.... it just takes a little twist of the wrist - you can probably even use a 1/4" drive screwdriver to snug them up. DON'T get TOO ROUGH!!
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
just wondering the minimum amount of panel removal before i get to the cover. cd is not
as helpful as i was expecting. looks like everything you take off putting on ron's sway bar.
Yeah, I had to learn the 3-D puzzle the hard way when I got my RTS. It was at 30K, and since I got it from the online dealer, I had no history on it. So I replaced the HCM, oil, fuel filters myself. Also had to replace the inner left side bag due to a broken hings. Not I'm fairly intimate with the tryke. (Got a post on here somewhere about that day)
As has been said though, if you know how to take the plastic off, the HCM is easy. Just follow the torque and patter specs and all will be well. No need for the dealer or BUDS.
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
didnt even think to pop the r front side cover off. hello! couple more pieces of plastic after the oil change stuff
and we will be there. got filter coming from baja ron. nuther 1000 miles or so to next oil change. ordered a set of brakes too for
later. and plugs. thanks guys !--irv
are the only 2 extra panels that actually need to come off- the r lower black side panel and
the square closeout below ? just from looking, i should have to take off the large rear side panel.
dont want to take off more than i need. i try to learn from my experience and you spyder experts.
done a lot more to it than i would have thought and have even helped a couple others.
try to
pay it forward.--thanks again.--irv toms
Seen one on YT believe it's done by You Own It A search should find it
