Results 1 to 19 of 19
    Mar 2020
    Cumming, GA
    Default Garage Door opener Spyder f3-S
    Has anyone figured an alternative set up for a garage opener on an F3?
    I have tried the MO-Door, but no matter what I did I could not get it to
    interface with my Genie Intelli 1000 opener.
    Suggestions other units?
    Thanks,
    Rotax
    Dec 2019
    VA
    2019 F3S SM6
    2019 F3S SM6 , Black metallic with pearl color change
    Jul 2019
    California
    I just use double back velcro tape to attach my opener to the inside back of the glove compartment. Simple to pull out to change battery. Have to stretch just a little to reach it, but much simpler than wiring something.
    Mar 2015
    Indianapolis, IN
    On our bikes I take a similar approach to WhoDat - cheap garage door opener, some solder - but instead of a button - I use a time delay relay and wire it directly to the high beams. ;-). Flash my lights and the garage opens. With the time delay relay if I turn on my high beams it's only activating the opener for half a second to a second and then the time delay relay cuts the signal - so I'm not running down my opener battery. No extra button needed on the bike - and it's not obvious to anyone at all.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    Keychain remote in my jacket pocket...
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
    Mar 2017
    Behind my GPS mount.
    Jun 2019
    South Bend, IN
    Having the same issue, very frustrating.
    Nov 2018
    Northern NV
    I took one of our garage door fobs, soldered a two-conductor wire to the button connections on the circuit board and connected that to a generic push button. I drilled the blank switch cover to the left of the handlebar and mounted the button there. The garage door opener is strapped to the frame can be accessed by removing the left inspection panel to change the battery when needed.
    2017 F3T , Black, black and more black
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I have not taked pics during intallation only the pushbutton final look.
    I used my 12 volts remote control by maintaning the little pusbuttion allways pressed and solding wires to the + & - battery contact.
    Positive ande negative come from owner accessories on the left side.
    The remote control is on the frunk left side with double adhesive tape fixed.
    Mine is the Ltd model.
    The green light is allways on. May be I could have activate this when pressing only but it could also have made more diffucult its location in the dark
    2018 F3 Ltd. , Black/Dark
    Florida Swamp
    My gate opener remote stays in the right vest pocket. Same place the Spyder key stays when it is not in the ignition.
    2019 F3-S , Black & Silver
    Active Member mstella101's Avatar
    Jul 2013
    Glen Ellyn, Il
    Rotax, when I got new garage door openers with multiple - I mean multiple attemps to hook them together and quite a bit of cussing it took me 2 weeks to finally realize I needed to take a paper clip and push in that hardly noticeable hole on the back of the unit. Did I feel dumb! Also had my wife push one button while I pushed the button on the motor opener while I was on the ladder. Hope this helps
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    I just did this with an existing remote thanks to whodat but I wanted to use a surface mount switch. This was the only place I could find to get this switch after searching the net, https://www.qualitymobilevideo.com/692.html
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Feb 2020
    CT and ME
    This is working great for me: https://www.homedepot.com/p/Genie-3-...3T-R/202808536
    Small enough to keep on keychain or jacket pocket.
    2020 F3S-SS , Titanium/Black
    Danbury Connecticut
    Quote Originally Posted by Rotax View Post
    Thanks,
    Rotax
    That's very disappointing. I was considering a Mo Door for the RT. Oh well................
    Thanks for the heads up.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Jul 2013
    Glen Ellyn, Il
    Don't give up on the Mo Door til you are sure it can't be programmed to your garage door. This was the first mod I put on my '17 F3LTD. I love it. Like I said in previous post I just had to figure out how to program it to my new opener(a chamberlain).
    But I must confess- there is no cooler feeling than hitting the button, revving the throttle and zooming into a still opening door and hoping I don't hit my head! It feels like the Batmobile going into the Bat Cave! OK - Fess UP! we are still like little kids riding our bikes growing up when we ride our Spyders! At least I am and hope that feeling never goes away! BAM-POW HAHA
    Mar 2020
    Cumming, GA
    Afternoon mstella101:
    I decided to Velcro the remote just above my left access panel. Works!
    Sep 2018
    Maryland
    Chamberlain Group MC100-P Universal Garage Door Opener Mini Keychain Remote, Small, Black
    I paid $30 bucks for it on Amazon, but it is currently unavailable. I like it on the keychain, very accessible and it goes where the keys go.
    2021 RT Limited , Fast Red
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    I added velcro to the back of ours and some velcro on the flat area between the handlebar and the display and just leave it there most of the time. If we stop at a restaurant, I'll put it in the trunk, but the rest of the time, it just lives where the velcro is.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Active Member kissfan's Avatar
    May 2019
    Brooker, FL
    Currently I have a keyfob opener on my Spyder keychain.
    When I had the two-wheeler, I used this:
    https://flashtoopen.com/pages/motorcycle
    My vice is passion for KISS.
    Oh, and food.
    Current ride: 2019 Spyder RT-L in Phoenix Orange.
    2019 RT-L , Phoenix Metallic Orange
