Results 1 to 15 of 15
    Active Member james199's Avatar
    Aug 2015
    New Mexico
    Default 2013 ST won’t crank
    Drove the st all day not one problem all day got home shut it off and that was the last time it’s run as now it won’t crank. It powers up but when I hit the start button all I hear is the fuel pump, no starter and I can’t get the bike into diagnostic mode. Could it be the computer.
    I have checked every fuse and relay I even swapped the relays with my other bike and still nothing.
    Any ideas
    Jan 2019
    Toowoomba Qld Australia
    Initially check battery terminal connections are tight. How is the battery?
    2014 ST-S SE5 Cognac
    2014 ST-S , Cognac
    Dec 2013
    Is it an SE or an SM? If it's an SE, could it just be that you aren't pressing hard enough on the brake pedal when you try the starter?? No brake, no start, especially if you shut it down while it was still in gear; and the brake micro switches can get a little sticky & dirty.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Bossier LoUiSiAna
    Step on brake , check battery connections :thumbup little odd however the pump starts with key not start switch. Least on mine
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2015
    New Mexico
    The battery is new and I have checked every fuse and relay. All I get is fuel pump but no start, I did try and jump the start solenoid and it will run as long as the start button is mashed. The bike has manual transmission ( with clutch) it’s in neutral parking break in gaged, I mean I have drove this thing forever and now it’s dead. I just wish I could get a code or something but like I posted earlier the bike won’t go into diagnostic mode either so I’m kinda lost. If I buy the Buds will it check all sensors and such.
    Dec 2013
    Just cos the battery is new, it doesn't necessarily mean it couldn't be the problem.... I reckon you'd be surprised at the number of problems we've seen here that have been fixed by replacing 'new & supposedly good' batteries! So if you haven't already, and you can manage a multi-meter, check the battery's charge condition 'cold'; and then check it again while you're trying to start it! It might even pay to put the battery on a good charger for 8 hours or so anyway, at least by doing that you can confirm the battery has a good cover charge, but even then it may still fail to have sufficient charge when put under load, and if you can't get the starter to actually crank, you won't be able to test that with just a readily available & relatively cheap multi-meter!!
    That said, jumping the starter solenoid and getting it to run while the start button is mashed does sorta suggest that something else is going on in the wiring &/or circuitry. Maybe it IS time for a trip to a dealer, or better yet, a reputable & knowledgeable Spyder Tech....
    Good Luck!
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Quote Originally Posted by james199 View Post
    ...I did try and jump the start solenoid and it will run as long as the start button is mashed...
    Elaborate on this statement.
    What runs, the starter motor or the engine is firing?
    What are the steps you are taking to enter diagnostic mode?
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Sep 2013
    Houston
    Just to rule out things,
    Key on, run/stop switch in down position, foot on brake, press and release mode button, Verify green N is lit for trans in neutral, pull in clutch, press start. If you do ALL of those and it still does not start you will need BUDS to find out which of those switches is not working.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Aug 2015
    New Mexico
    I have done all of those steps a 100000 times and even more since it’s hasn’t started. I have tried EVERYTHING to get it into Diagnostic mode to no avail. I am going to buy the buds I just hope it tells me something.
    Aug 2015
    New Mexico
    Quote Originally Posted by SportsterDoc View Post
    Bike will Not go into Diagnostic mode, the Only thing that runs is the fuel pump when the start button is in gagged.
    I think #6. - Peter Aawen hit the mark ..... Mike
    May 2020
    New Mexico
    What is the battery voltage with the ignition off?
    What is the battery voltage when the start button is pushed?
    Sep 2013
    Houston
    If by diagnostic mode you mean the 3 button press to get the error codes, there is nothing to display unless the check engine light is on. If the light is not on, the ecm thinks everything is fine. Using BUDS you will need to test each of the start interlock switches to determine which one is not working correctly.
    Aug 2015
    New Mexico
    I get no codes so I guess I’ll spend the cash and order buds. My local shop where I bought my bike is now permanently closed and when I bought my bike I paid for a extended warranty only to find out I don’t have said warranty or my money so I have to fix my own bike now. Today when I turned on the ignition & I didn’t have to press the mode button to start, my cluster just came on & the bike now just boots up ( the cluster comes on ) no matter how long the key is off and away from the bike.
    May 2020
    New Mexico
    Who under wrote the extended warranty?
