Results 1 to 25 of 25
    Jun 2020
    South Carolina
    Default accessory installation for 2020 RT
    We are planning to get the driver backrest, passenger armrests, and the auxiliary light. Should we pay for installation at dealer or are they pretty easy to install?
    Danbury Connecticut
    Pretty easy to install.
    Having said that, it should be pretty easy for your dealer to install also, and shouldn't cost much extra.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Durham,Maine
    Like everything on these things there's going to be some panel removal going on there, so if your cool with all of that it should be a easy thing! Good luck!
    2012 RTL , Pearl
    Bossier LoUiSiAna
    Ease or not they go by BRP rated time estimates at expensive shop rates & DIY you get to know your bike better for the unexpected things that happen on the road just take your time , don’t get aggravated & brake something
    Oct 2014
    Ohio
    Quote Originally Posted by kokeshi View Post
    My dealer installed the rider backrest and Garmin GPS mount at no charge. Although the GPS Mount had no power when I got home to try it. I had to do it over, the polarity was reversed, so obviously the Dealer never checked it. I guess you get what you pay for.
    Sebring, FL
    Back rest was easy, except for the L shape bike support, but that was on me. The the front aux light is pretty much plug and play, arm rests, that a dealer shop job.
    Mar 2013
    Maumelle, AR
    The backrest and auxiliary light are pretty easy to install. Even a Caveman can do it. I don't know about the passenger armrests.
    *** Note*** Has your passenger sat on one with the passenger armrests? My understanding is that it could be a little difficult to get on and off with them. A few people on here have gotten them and then took them off because of that. It could be a costly mistake.
    2020 RT Limited , Chalk
    Including the accessories in the OTD price is a good idea to see how much the dealership will include to have a satisfied customer. It might also give you some leverage if there is more than one dealership within reasonable shopping distance. Create a spreadsheet and list everything to get a bottom line number and shop it hard.
    Sebring, FL
    Quote Originally Posted by Copperman View Post
    It is indeed tight for the passenger to mount and dismount, why o why BRP did not have them fold up is beyond me. I had nothing to go by when I had the dealer install because the wife wanted them for our TN trip and mountain carving, so it is what it is. If I had it to do over, I might wait for an after market. But I did get an OEM set very reasonable from a rider that removed his for the very reason it was too tight for his passenger.
    x 2 There is enough markup in accessories that the dealer has a bit to play with here. You should be able to work out some kind of "install" deal if you so desire.
    Sebring, FL
    Install is a big deal unless you're one of those that enjoys that mechanical stuff and it's therapeutic, and is nimble. Installation of accessories takes a lot of patience and time. One little screw up is demoralizing.
    Feb 2020
    N. Wilkesboro, NC
    Yes, it is.
    Feb 2020
    N. Wilkesboro, NC
    Unless the dealer is one of those who thinks 1 customer doesn't matter. (previously discussed) If that's the case, it doesn't matter what you do or say. Still, can't hurt to ask.
    Apr 2012
    Florida
    The light is probably the easiest to install accessory that BRP sells! Took me all of 5 minutes. The backrest should be another easy install. The armrests? Sounds like some work. Let the dealer do the armrests. Tom
    2020 Petrol Blue Metallic RTL
    Quote Originally Posted by MONK View Post
    When we get to this point, IMO, time to find another dealer if possible. No one likes being treated like do do, and you even end up paying them for that.
    Jun 2020
    South Carolina
    Thanks to all your replies. I will definitely see (as best I can) if the armrests will be comfortable before installing.
    Aug 2018
    north wis
    My wife has always got on the drivers seat and slid back to her spot and has no prob on the 20. She really likes the uptick on the front of the arm rests and finds them very comfortable.
    Dec 2018
    Long Island
    You can go to the owners section on the BRP web page and review the installation instructions to determine the ease or difficulty of the installation.
    Sebring, FL
    Hey Woods by golly, that's a good tip, I'll pass that along to the wife.
    Jun 2020
    South Carolina
    Thanks to all.
    Jun 2020
    South Carolina
    We got the auxiliary light installed. My husband even bought one of those torx ratchets to make sure it was tightened right, like it said in the instructions. Is there anything that needs to be hooked up, like a wire connection? The auxiliary light doesn't come on.
    May 2020
    MA
    Yes there is a wire behind the plate. Plug it in, screw in the light and it should be all set
    Jun 2020
    South Carolina
    We snapped the light unit into the wired recepacle, then put the 4 screws into the holes to attach it to the bike. Are we missing something, or did we just get a bad light?
    Mar 2013
    Maumelle, AR
    It only works with the motor running.
    Aug 2018
    Huntsville AL
    The 2020'S are a lot easier to work on than the earlier RT's. Lower light in front is a plug and play with four screw to install, no drilling. Arm rest could be a little tougher you have the two side panels to remove that is where the arm rest mounts.
    Is it's BRP parts installed by a dealer tech that you should have warranty coverage on the parts also.
    Good luck
    SpyDerred15
