Results 1 to 23 of 23
    Active Member spyderryder53's Avatar
    Hanover CT
    Default Headlight problem
    My left LED headlight went out so I replaced the bulb and it still doesn't work. I tried 2 new bulbs, the right one works so I doubt it's a fuse any ideas?
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
    Nov 2019
    PA
    I'm sure this doesn't apply to your situation, but my story is sort of similar:I took delivery of a new 2020 RTL a couple weeks ago and within the first day of riding noticed that my right front turn signal was not working. The running light on the fender was also out. Took a week and a half to get an appointment with the dealer. Turns out the tech never plugged the light in when they did their initial setup prior to delivery. It didn't occur to me to check all the lights before I took delivery. Lesson learned.
    Hanover CT
    I have a 2014 RTS, my right led headlight went out so I called and got replacement set, I changed the bulb and it still doesn't work.I tried both new bulbs and it is plugged in and locked the right way. The left works so I doubt it's a fuse.
    ANY IDEAS WHAT IT COULD BE ?
    AND
    Are you saying you replaced the burned out LED headlight with a replacement LED headlight or did you replace it with a halogen? If you replaced it with a LED bulb is it possible you got the polarity reversed? Try a halogen in the right and if it works you got the LED polarity reversed.
    Hanover CT
    The plug has a lock together clip on only one side and its locked in so not sure how the polarity would be reversed. Maybe the burnt out bulb isn't bad and its another problem.
    AND
    May 2019
    Carlton
    I replaced my Halogen bulbs on my RT with LED ones..fitted them the way they looked they should go and they didnt work... you can just turn the plugs around on the led bulbs as they can fit both ways. I pulled my plug out..turned them 180 degrees and refitted them ..bingo they work!.. So if its a bulb just try unplugging turn it around and replug it in..could be a polarity problem.
    Bossier LoUiSiAna
    Quote Originally Posted by spyderryder53 View Post
    swap with Rh side test all bulbs on known working side. Label/mark bulbs somehow help keep yourself organized. Inspect if spade blades are tight & same size, if had any trouble putting led in may have spread connections & vibrations eventually made worse. &or the blade went behind the connector not in. Happens all to often in tight spaces.
    Durham,Maine
    Take a multi tester and check these burnt out bulbs for continuity to see if they are really gone so your not chasing your tail!
    2012 RTL , Pearl
    Hanover CT
    Ok EVERYBODY that said it was a polarity problem you were RIGHT
    When I said the plug only goes in 1 way that was the PLUGS to the Bike.
    The plug for the bulb does have a tip for locking it in on both sides.
    I HAD IT IN BACKWARDS AND WHEN I TRIED A DIFFERENT BULB MUST HAVE PUT IT BACKWARDS AGAIN. THANK YOU ALL VERY MUCH FOR THE HELP
    AND
    Hanover CT
    You were 100% correct thank you.
    AND
    Hanover CT
    Quote Originally Posted by Curlytops View Post
    You were 100% correct I had it reversed, thanks
    AND
    Sep 2012
    Stetson, Maine
    Great job. Thanks for letting us know the final outcome.
    L
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Vermont
    In 2017, I had a headlight on the right side,that was brunt out, I replaced the headlights/fog lights with LED'S.
    I have not had a problem since.
    I have 2014RTS- SE6.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Member Hoodrich13's Avatar
    Jul 2019
    NC
    Ok. So i could use some help. 2015 F3S. Installed led headlights and they work fine until dusk when the headlights automatically adjust. They only work as high beams and wont turn off. 1 side actually went out. They are brand new bulbs. Didnt see a way to plug them in another way.
    3 hrs out of town in need of help.
    Keep your wheels down and your head up
    Be safe and ride hard
    2021 F3L , Black (for now)
    Quote Originally Posted by Hoodrich13 View Post
    What exactly do you mean when you say the headlights automatically adjust at dusk??
    Is there some after market headlight on/adjust kit that someone's added to your particular F3; or is it an 'auto on' option that we don't get here in Oz & that no-one else here has happened to mention yet??
    SoFlo
    I am probably incorrect, but have never heard of Spyder headlights having an automatic dimming feature.
    When you mention high beams will not turn off, I take this to mean high beams will not switch to low beams as opposed to the headlights remaining illuminated after complete shutdown?
    Jul 2019
    NC
    After checking my lights this morning, i realized that coincidentally my left light cut out as it was getting dark. I thought it was like my car. Daytime running lights and headlights when it gets dusk. I guess when the light went out, it became high beam only. Gonna take it apart after a lowes/ harbor freight trip and see how it goes before we head to Knoxville. Thanx guys.
    I see you posted your lights were fixed.
    Don't know what the deal is, but several 2014's have experienced premature headlight failure. Mine included. The right hand side one burnt out twice. I finally replaced with LED's from custom dynamics.
    Dealer did the install and overtightened the high beam/low beam flap. Result was I had one stuck on high beam. Loosened it up and it has been working well for about three years.
    SoFlo
    Since you have the small DTRL setup, it will be both headlights and DTRL on once Spyder starts regardless of ambient light. High beams must be selected on.
    When you have a bulb failure on an RT series, you will have failure of both low beam and high beam since the bulb is single element. OEM halogen bulbs are known to fail. Most people swap to LED bulbs. Be warned though, you must ensure the wiring inside the headlight assembly does not foul the movement of the high beam shutter, preventing it from properly moving. Upgrading the set of headlights is worthwhile and safer. You should consider buying proven quality LED setups since replacement is a bit involved but not impossible.
    Jul 2019
    NC
    The problem i am currently trying to resolve is on a 2015 F3S. My right headlight went out and the left only worked as high beam. It would not switch to low beam. I appreciate any words of wisdom as i am trying to fix this out of town with none of my tools.
    Jul 2019
    NC
    My lights are LED
    Dec 2012
    Murphy, NC
    I have an F3-S with LED's also. The only thing I can think of is that you might have a bad headlight switch on your handlebar cluster.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Jan 2021
    Limestone tn
    Replaced headlights and foglamps with led bulbs on 2014. Rt installed tricled 360 headlight bulb's and right bulb would not illuminate, when plugged left headlight assembly in right harness bulb would work , plugged hid bulb in would work. Started inspecting harness and polarity found connector inside cover at bulb wires in rong position in two pin connector from factory. Connector is marked positive and negative and the black wire(negative)was in the positive postion,reversed wires in connector and led bulb works like it should, on the left side connector the wires were in the correct postion. (Tricled 360 led headlight bulbs will fit inside cover with no cutting or mounting outside of cover)
