Results 1 to 7 of 7
Thread: Belt tension
    Jun 2015
    carmi il
    Default Belt tension
    What is the current recommended belt tension for a 2015 f3s ?
    Recommended by who ???? .... Most folks here have had great success with 150-160 lbs using a KritKit ... measured " on the ground ". I use this and have none to very, very little vibes ..... Mike
    Harrington, Australia
    I dropped my F3-L tension to around 155lbs, based on Mike’s experience, and then removed my aftermarket tensioner that was showing signs of wear. Vibration is now virtually non existent, so dropping the BRP recommended tension worked for me, too.
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2015
    carmi il
    Thank you.
    Mar 2015
    Indianapolis, IN
    Are you suppose to measure the tension from the top if the belt down or the bottom of the belt up? Thanks!
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    What is the recommended cricket measurement for the old RS (2010) belts while on the ground? I should check mine. Thanks. Nevermind, found an old thread that said 160-180 for my RS. Thanks.
    Jul 2016
    australia
    Top of belt down in the middle of span
