Frozen sway bar link
While working on our 2015 Spyder RT....had a clicking sound when rocking bike side to side...found a frozen BaJa Ron Link...
I removed both links.....had hit the frozen one with a hammer(several times) ...used WD40...put it in a vise and got it to free up...but its tight but now moving...
I cleaned the other three and they are very free moving.
Anyone had this problem....Did you or can you see any steering problems with this frozen link.
BIG question....should I replace these two links with new one's????
Comments are Welcome!!!
Your best bet is to PM, or better, email Ron and ask his advice. He'll work out something fair I'm sure.
I had a similar issue about a year ago with mine as well from them. I noticed a squeaking noise and one was stuck. I cleaned them lightly with a Scotchbrite pad, solvent (mineral spirits) to cleanup, then liberally applied some axle grease to the rod end balls. Moved the links around by hand to distribute the grease. I haven't had an issue with them since. Although, I haven't looked at them for some time. It may be time to do it again, but I haven't heart any noise. Easy fix and part of the maintenance ritual. They don't appear to be a high end stainless like a Hiem bearing used on aircraft, nor the cost. But, the setup works great.
Life is attitude, be positive!
same with me. take em off and lube them once in a while.
[joyce & irvin toms]
I have a clunking /clicking sound when I rock back and forth too. I guess I'll check the links. Seems a grease fitting or two would be handy
I had similar clunking noise so I decided to install the OE units for the meantime. No clicking/clunking noise anymore. I suspect the noise is because the ball has a small amount of play in the socket since it isn't pressed in, Its just held in place with snap ring.
Tags for this Thread
