Results 1 to 15 of 15
    TX
    Default LED headlights in a RSS
    Has anyone put the new style LED's in an RSS - I have to replace one of the halogen ones and wanted to upgrade unless there isn't enough room under the gage
    thanks
    ted
    Default Not sure...
    Have not done a extensive search but so far I have not found a kit or set for the GS,RS,RSS models. If you find one let us know....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2016
    australia
    I fitted leds to the lower lights ln a 08 gs today.they are hb3 in Australia. Any hb3 will fit.i use jw speaker here in aus.dont be tempted to buy cheapies
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    Got LED's in high/low, fog and running lights, got them from a company I used to work for CarId. Love them direct fit 20161124_165343.jpg20161124_165343.jpg
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
    Jan 2019
    Alliston Ontario
    I just fitted LED's to my 2008 RS TODAY I'll post a tutorial on how to do it! Theres some tricky things about the rertainers that need to be addressed!..
    Cheers Dave
    Nov 2008
    las vegas, nv
    When I replaced mine with HID, I ended up pulling cougar head off.
    Just not enough room in there... I bent the flimsy metal holder on my first RS also when I did that one too.
    Bulb size is h7 and I would think any h7 led replacement could fit but most vendors do have physical dimension listed.
    Also, I think I’ve seen a vendor here have them.
    6 states down 42 states to go
    Jul 2018
    Lake Stevens, WA
    banggood.com for direct fit replacement
    2009 GS , MSD wires Red/Black
    Jun 2019
    Scottsdale, Tasmania
    I replaced my low beam and high beam globes with LEDs and then did the 4 eyes conversion so that when I switch from low to high beam the lows get turned back on. Well worth the money.
    2014 RSS , 4 eyes conversion for headlights, 12v socket, 2x USB Ports, CTEK Charging Port. Black and White
    Feb 2020
    Worcester, Massachusetts
    Working on my 08 today, 2nd attempt at LED headlights. 1st one I bought a style of bulb that would not work with the power connector.
    Now got Mercedes style clips but had a very hard time trying to put them in place. Might have to take the whole head off, space is too tight for my hands.
    Foglights were easy to change, but got "limp home mode" after installation. It's weird how sensitive the computer is to LED lights. Had same problem with the tail lights but solved it today adding 2 sockets and keeping the halogen lighs tucked inside.
    Anyone had the Limp problem with LED headlights?
    Apr 2010
    La Plata, Maryland
    LEDs are a pain. Here are the pictures of my process putting LEDs in my 08 GS.Spyder3.jpgSpyder1.jpgSpyder2.jpg
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    I personally would find it extremely helpful if those of you who find a direct fit LED replacement for the H7 headlight bulbs on our GS, RS, RSS models would please give the part # and supplier/link for them
    I don't find it at all helpful when a post says: Amazon or Banggood has them as the choice is huge
    Also, if you need to buy a pair of clips for them, I find stating 'Mercedes clips work' is not enough info. Exactly which model Mercedes would help as well as part #, supplier, link.
    Thank you, rant over. Have a nice day!
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Feb 2020
    Quote Originally Posted by jayallday01 View Post
    How do you get the dash up like that? I'm 100% new to motorcycles, bought the Spyder in December, will be registered this week, now that weather will get somewhat better.
    Also, have you had any problems with Limp Mode after the LEDs installation?
    Apr 2010
    La Plata, Maryland
    In the middle picture there is that square bracket in the center. There are 2 10mm bolts that hold it down. They are not easy to get to, unless you have a swivel socket and lots of patience. you may have to trim the plastic piece right behind there to wiggle the console out. Once you get it it out, access is much much better.
    So far I have not had any issues with limp mode.
    Active Member krakum1967's Avatar
    Dec 2019
    Western Colorado
    My HID Xenon Kit arrives tomorrow, figured I need to pull the gauge cluster to do my bar risers, so I might as well get these done. I found a nicer set that are not returns for 114 dollars, and bought them, I think there are two more sets on FleaBay under 200. One of them looks like a return item, and I cant stand when people send stuff back after giving up on a project. Anyway, I hope it goes well, the stock H7's suck.
    Kraig B. Kumlin, M.M., M.C.P. (Retired)
    Only Two States Left to Visit on MC or Trike, RI and CT
    2012 RS-S , Baja Ron Plug Wire Kit and NGK Iridium Plugs Grey and Black
    Jun 2019
    I have a 2014 RSS and I just removed the dash cluster and fitter the LED globes in through the hole easy as.
