Results 1 to 10 of 10
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default Amber lens missing
    2010 RT Spyder - I have lost the amber lens that covers the left side front wheel running light. It is rhomboid shaped like a flattened rectangle. Where can I get a replacement lens cover? Can-Am website? One of our vendors?
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    You can go here for to find the p/n's http://epc.brp.com/Index.aspx?lang=E...rands=roadster
    Once you have the p/n look it up on google to see who has the part in stock. Sometimes you can find used parts on eBay.
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Jul 2014
    Mint Hill, NC
    I do not find a separate PN for the lens on the BRP parts list for the fender; the diagram of the fender lists only the fender itself. You might be wise to contact a dealership parts dept to verify. If they can't give you a PN you're looking at finding a fender from a damaged vehicle, I think.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Nov 2015
    Chardon, OH
    Quote Originally Posted by BigGuy66 View Post
    Hey Jim. I’m assuming here, that you are talking about the electrical tip light and not the amber side reflector ( 705002423 )
    In the parts listings, the light is listed under Electrical Accessories - Front. 710001478. Looks like you have to buy the entire socket assembly and just use the parts you need. To my knowledge, all the lenses were clear. However, there was a choice between amber and white replacement LED bulbs among some vendors. Do you think your lens is actually amber or just faded / yellowed clear? I'm not aware of anyone offering a true, amber lens, just the amber bulb. We run the white LED bulb. Very bright.
    https://www.amazon.com/Spyder-2010-2.../dp/B079RY597D
    http://store.valueaccessories.net/LE...-AMSpyder.aspx
    Doug
    ”Freedom is not a loophole”
    Jul 2014
    Mint Hill, NC
    Snowbelt, thanks for pointing out my poor old eyesight. That having to buy the whole light business is the same thing some F3 owners who have lost the taillight lens have had to go through.
    Cognac 2014 RT-S
    Nov 2015
    Chardon, OH
    Yeah. Otherwise, this is the only other true amber lens I can think of for the front fender. Jim, it’s not OEM, and don’t know if you could get just the lens.
    http://www.bigbikeparts.com/template...A&GroupGuid=78
    Doug
    Feb 2012
    Spring City,Utah
    Are you talking about the amber reflector on the left fender?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2010
    Las Vegas
    If it is stock it is a reflector, if it is a light you can get one at www.tricled.com
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2016
    Quote Originally Posted by Snowbelt Spyder View Post
    This is exactly the lens that I am talking about. It must be the after market Amber LED Marker that the former owner put on. I assumed it was BRP... nope.
    Aug 2016
    It is actually an LED assembly that blinks with the turn signals. I think Snowbelt Spyder has tracked it down for me.
Tags for this Thread
