Results 1 to 6 of 6
    Feb 2019
    England
    Default Connection of sat nav
    Hi all can any member say if the connections that can power a phone in Ryker trunk , will keep a sat nav working if plugged in . I am thinking of cluster relocation and am making a fitting to put sat nav on to handlebar in central position in place of speedo. If not is there a power connection under the side panels ( the ones that cover h/ lights
    Thanking you nico 75
    Feb 2020
    N. Wilkesboro, NC
    I don't know anything about the Rykers but I'd be wary about removing the speedo/guage cluster. I'll bet that has all sorts of electronics that will cause the bike to not run if it's removed.
    Mar 2019
    Ky
    Quote Originally Posted by MONK View Post
    Its a dealer accessory option to relocate the cluster.
    Feb 2020
    N. Wilkesboro, NC
    Guess I read that as "removing" not "relocating". My bad.
    Nov 2012
    North Las Vegas, NV
    I connected my sat nav to the back of the usb charger in the frunk/glovebox. Works fine.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Feb 2019
    England
    Thanks Highwayman2013 ,that’s what I was after regards nico75
