Results 1 to 4 of 4
Thread: radio issues
    Oct 2013
    rome new york
    Default radio issues
    Have 18 F3 Limited.
    Radio worked fine first 800 miles. Works fine with just ignition on, Soon as you start it get just static ,
    Anyone have any ideas and where to look?
    TIA
    Mar 2013
    Marion, Arkansas
    Did you install LED fog lights? If so turn your fog lights off and see how the radio is. If the radio now plays with the fog lights off, call either SpyderPops or Lamont for a solution
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Quote Originally Posted by Ex-Rocket View Post
    .... this is a common problem with some LED headlights .... I had great radio reception until I switched to LED's ..... they were replaced by the vendor and no further issues ..... Mike
    Active Member Seattle's Avatar
    Nov 2008
    Seattle
    Does the audio system static sound like this on your Spyder. If so, here's my detailed explanation of what's required to resolve the static if it's the same issue. My first post about this issue goes into further detail of what I've been experiencing only to discover this is quite common on every 2018 model Spyder including some 2019 models, but not all.
    I hope this will help.
    “Be who you are and say what you feel
    because those who mind don't matter and
    those who matter don't mind.”
    ... Dr. Suess
    (\__/)
    (")_(")
    2018 F3 Limited - 10th Anniversary Ed , Trickle charger, Gerbing heated clothing Black/Gold
