Results 1 to 3 of 3
Thread: Help please!
    Jun 2017
    Missouri
    Default Help please!
    I have a 14 Spyder ST SE5. Just replaced the battery since I figured it was getting old. Went out to start it and turned the key on and nothing happened, no lights on dash, no headlights but the alarm when you don’t put parking brake on went off and wouldn’t stop for over two hours. I checked all the smaller fuses and they are good but haven’t checked the relays. Battery at posts tests good and is fully charged. Any help is much appreciated.
    Bossier LoUiSiAna
    Polarity correct & terminals tight? You say checks good, what is that voltage? Was battery load tested? Try again & slowly go over start up procedures; key, kill switch, brake applied (park brake on or not) SE5 funny like that.
    Jun 2017
    Missouri
    Yes battery was load tested. The trike was rode up after battery was replaced with no Issues. The polarity is correct. The screen and everything doesn’t come on. Didn’t know if there was a main fuse somewhere that I’m not seeing. I checked the fuses in the frunk and all looked good but didn’t test or check relays.
