Results 1 to 8 of 8
Thread: Battery Tender
    Active Member View from behind's Avatar
    Aug 2015
    Taylors SC
    Default Battery Tender
    We have purchased a new Yuasa (same as OEM) battery and would like to use a battery tender but not sure which is compatible with the AGM battery. We have been using an older battery tender we had for a BMW which had a Gel battery and specifically says programmed for Gel batteries. Yuasa says this battery tender should not be used with a AGM battery. What are others using?
    Thanks in advance.
    Nov 2018
    Waynesboro, PA
    This is what I use on my Spyder and Tractor. Battery Tender Junior Charger and Maintainer, EXTENDED BATTERY LIFE: Compatible with lead-acid, flooded, and sealed maintenance free batteries (AGM and gel cell) to be ideal for use in long term storage. Complete 4-step charging program (Initialization, Bulk Charge, Float Mode) allows for optimization of battery power, without overcharging.
    My Spyder
    2012 RTL , Brown
    Jul 2014
    Mint Hill, NC
    +1 for Battery Tender Junior.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Quote Originally Posted by CopperSpyder View Post
    -- can't go wrong with a Deltran
    Jul 2018
    Fountain Hills,AZ
    Battery Tender all the way I have 6 of them work great!!
    Aug 2015
    Taylors SC
    After doing some searching on the web, we're not convinced that the Battery Tender Plus that we have, isn't compatible with the AGM battery. Makes us wonder if Deltrean just wanted us to buy a new one and Yuasa wanted us to buy one of theirs.
    I have five of the Deltran Battery Tender Jr.s. This was the first year I did not have to use them. We ride all year here in AR. The John Deere lawnmower was hooked up though.
    Dec 2019
    Land of Lincoln
    https://www.amazon.com/dp/B07W6B987F...xoCQpoQAvD_BwE
    NOCO. Modern electronics, 100% reliable.
