Results 1 to 21 of 21
    Nov 2018
    Des Moines IA
    Default Anybody use seat beads
    I am looking at a beaded seat for the 2020 RTL. What size does everyone use?
    2018 Spyder ST Limited , Asphalt Gray
    I use seat beads on long rides. I rotate from the seat beads to just the seat itself. Seat beads give your back side a different feel and it's good for awhile. Swapping back and forth gets me further down the road. They also help on hot days as it lets air circulate rather than just sitting on vinyl.
    They are not the end-all for me. But a nice aid for a little more comfort. Mine is just big enough to cover everywhere my body would be touching the seat.
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    I also use the beads when my butt starts to get sore on a long trip, or when it gets hot in the summer.
    They are definitely more comfortable than they look.
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Mar 2013
    Maumelle, AR
    Beadrider.com They have measuring instructions.
    2020 RT Limited , Chalk
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    I have been using an Airhawk seat pad for about 15 years. I highly recommend if you are long distance rider.
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Sep 2009
    La Valle, WI
    I have one. Can only use for a short time. But it does get air under you on a hot day. My buddy uses it some. He likes it better than I do.
    2018 F3 Limited , Oxford Blue
    Nov 2018
    Des Moines IA
    Quote Originally Posted by upsdoctor View Post
    Thanks for the input. Comfort isn't the issue. I have tried the Airhawk seat pad many times on long trips. It just doesn't work for me. I am looking at the ability to keep the backside cooler.
    Aug 2019
    Stoughton, WI
    I have them all. Beads, sheepskin, air pads and vent pads. Beads do keep you cool in the heat. I like this best, as it vents, adds a touch of cushion and is grippy when cornering. Size M https://www.cyclegear.com/parts/speedmetal-air-seat-pad
    2022 RT Sea To Sky
    Aug 2012
    Central Coast, CA
    I have made several bead seats for different motorcycles, so you can custom size it. It's quick and easy to do. You just go to WallyWorld or a chain auto parts store and buy a bead seat cover for car seats, like the Tijuana taxis. You just unweave it to the desired size and shape, and then tie off the corners where you did the unweaving. It's held in place with either cords or small bungees. On my previous 2014 RT, my wife loved it for the cooling effect. Me not so much.
    2020 RTL SE6
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
    Wow , thanks for the info ( I just ordered one ) .... I was quite interested in the " beadrider " one - until I saw the cost with shipping added .... The measurements for the one on E-bay is mis-leading, they didn't add the front section measure which is at 2in. .... so it's really the same size as the one " beadrider " recommends for the Spyder ....... ..................Mike
    Aug 2019
    Stoughton, WI
    The seat beads are damn near a custom fit on my Seth Laam re-done F3S seat. The Speedmetal vent pad also fits nicely.
    2022 RT Sea To Sky
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    I'm gonna try one of those as well, my wife and I went for a pretty long ride yesterday through the Hills and by the time I got home the "boys" were very unhappy. All of a sudden it feels like the "boys" are getting rolled back the longer I ride. Had to stand up and get readjusted frequently.
    Bob S
    Dec 2015
    NE Ohio
    I had a bead pad for awhile, it was the plastic beads. No cover came with mine though. Made a quick turn onto a side road and almost slid off my seat. Maybe the wooden ones are not as slick. Now use an Airhawk and it works well.
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Put the wrong site in. Should be the Cycle Gear site. https://www.cyclegear.com/parts/speedmetal-air-seat-pad
    I have use one of these air mesh seat from Cycle Gear with the vinyl on the under side cut out so that flows. It is great, but the vinyl has to be cut out for the air flow.
    Can Am 2013 RTL SE5
    Feb 2020
    N. Wilkesboro, NC
    I'm NOT trying to be rude, mean or anything else but I thought they whole point of spending uber bucks on a Laam seat was so you didn't have to add anything else for comfort?
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by MONK View Post
    Seat beads offer ventilation that black vinyl does not in warmer temps..
    2022 RT Sea To Sky
    Oct 2015
    Get a air hawk r seat, they have return policy if u dont like it u can return it for a full refund/ IPROMIS U THAT U WILL NOT RETURN IT
    Aug 2019
    Stoughton, WI
    Well .. Gonna go out on a limb and say I have just about all of them. Beads, sheepskin, air, gel and ventilated
    2022 RT Sea To Sky
    Nov 2018
    Des Moines IA
    I have a sheep skin that I use in cooler weather. I may try it in hot weather to see if it works.
    Nov 2016
    Northport Alabama
    I took my seat off and to the upholstery shop they dipped it out where my tail bone hit at and under both hipps added real dense thick foam and now it rides like a ultimate seat. Completely cured my tail bone pounding .I tookit on a 250 mile trip Im now in love with that seat.
