Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Default Ryker rear fender “luggage” provisions
    Wanting to be able to strap a small bag (~6x14”) and/or a light weight jacket onto the rear fender, I ordered four black oxide footman’s loops, to mount directly to the plastic fender. Load is not expected to be more than two, perhaps three pounds.
    Holes are 1 1/4 inches from the edge of the fender, which fits between structural ribs and are 6 1/8 inches apart going across the fender.
    Preparing to use 5 mm flat head screws the holes were drilled to 3/16 inch...allowing enough interference for the screws to thread into the plastic to better hold them in place while adding a washer and then a lock nut.
    The second hole for each loop will be drilled after the loops are mounted through the first hole.
    I enjoy custom modifications and want to keep the Ryker more sporty, rather than adding touring luggage.
    This should be much easier than what I did on the Moto Guzzi:
    https://wildguzzi.com/forum/index.php?topic=89090.0
    ...to be continued
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Have you thought about when you go over any bumps? That area above the plastic fender is clearance for the the rear swing arm. Anything mounted to it could get crushed or impede your shock travel.
    May 2020
    New Mexico
    Quote Originally Posted by Markubis View Post
    Thank you for your concern
    1. There is nothing over the rear fender, with a solo seat.
    2. Clearances were a consideration for the Moto Guzzi, including opening without contacting mufflers.
    This link explains pre-fab preparation
    https://wildguzzi.com/forum/index.ph...164#msg1405164
    Jan 2018
    NH
    Ahh, ok....I didn't know it was a solo seat.
    Still, wouldn't getting the max mount extension up behind the solo seat allow for more allowable carrying weight?
    Aug 2015
    Crosby,Texas
    The Ryker rear fender mounted to the swing arm drive shaft & rear wheel. The Guzzi rear fender is mounted to the frame. Not the same thing.
    May 2020
    New Mexico
    Don’t need to carry much weight, per post one: “ Load is not expected to be more than two, perhaps three pounds.”
    I prefer the Ryker’s solo seat appearance.
    Footman loops should arrive tomorrow. Expect more photos.
    May 2020
    New Mexico
    Quote Originally Posted by KID Ryker View Post
    The Ryker rear fender mounted to the swing arm drive shaft & rear wheel. The Guzzi rear fender is mounted to the frame...
    I mounted the Pelican cases to the frame of the Goose. They were extremely rigid.
    My point, or attempted point, is that all clearances and stresses were carefully considered before proceeding with the mod.
    May 2020
    New Mexico
    Maybe this will better explain the expected function.
    The bag (2 for $10 at Lowe’s)...
    https://www.lowes.com/pd/AWP-14-in-Z...E&gclsrc=aw.ds
    ...contains a nylon shell fleece lined “warmup” jacket.
    Bag and jacket weigh 2 1/4 pounds.
    It will be lower profile, strapped down, although I could put the jacket under the bag, to add light weight gear to the bag
    Dec 2013
    Lotsa older 'bikes used to do just that... (think WLA Harley - IIRC the carry rack & rear panniers were all fender mounted?!?) I don't see why it would be too much of an issue for lightweight gear, or hard to do for that matter?!
    Be interested to see pics of it being done, as well as the final result!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    May 2020
    New Mexico
    Should receive the footman loops tomorrow.
    Just 4 more holes to drill.
    Put a putty knife under the fender, should the drill bit break through too far.
    May 2020
    New Mexico
    Loops arrived and installed.
    Not much clearance under fender, but sufficient to install SST fender washers and locknuts.
    May 2020
    New Mexico
    Photos of jacket and/or bag strapped down
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    cool.
    2019 Ryler Rally , Shock Yellow
    Jan 2018
    NH
    Quote Originally Posted by SportsterDoc View Post
    Well done. My only worry is the threaded side of the bolt is near the tire and will get dirty and difficult to remove.
    I think I would have flipped the bolts around and had the nuts facing up. Then use castle nuts on the threads to keep it clean looking.
    May 2019
    OH
    i was skeptical of this when i first saw you trying it. looks pretty good tho
    May 2020
    New Mexico
    Footman loops are designed for flat head screws (3mm hex bit-Allen)
    Do not expect to ever remove, but if necessary, spray cleaner and old toothbrush would remove dirt for access by 8mm box wrench.
    Fasteners (screws, fender washers & lock nuts) are all stainless steel.
    May 2020
    New Mexico
    Quote Originally Posted by mjl99 View Post
    Thank you, but this was not much of a challenge. The last 20 years of my different careers was industrial automation (systems integrator-automation house). When I retired 3 years ago, at age 70, the most difficult aspect of retirement was leaving a complete machine shop.
    Feb 2019
    England
    Hi SportsterDoc ref plc of bolts , the threads should have been cut flush with castellated nuts , you need a much clearance as possible, but it’s a nice idea and well done regards nico75
    Jan 2019
    Toowoomba Qld Australia
    Nice job and great result!
    2014 ST-S SE5 Cognac
    2014 ST-S , Cognac
    May 2020
    New Mexico
    Quote Originally Posted by Nico75 View Post
    Considering that the fender does not move in relation to the tire, 19 mm of minimum clearance to tip of screw seems adequate and removing 1-2 mm not worth tire removal.
    Screws are A-2 (A2-70) stainless, so filing or cutting with hacksaw would not be easy with tire in place.
    To grind off protrusion would require tire removal and heat generated may affect the nylon insert in the locking nuts.
    That's my story and I am sticking to it!
    Feb 2019
    England
    Well done nico 75
    Feb 2020
    Oceanside, Ca.
    Consider attaching two pieces of round stock to the two holes directly under your seat. I did it using 1/2 inch emt and fabricated a bolt up system thru the existing holes. I works slick holding a small carry-on piece of luggage.
    May 2020
    New Mexico
    I did consider a custom rack attached to the seat, but since a machine shop is no longer at my disposal, decided I would not be satisfied and it would endup in the recycle bin. Meanwhile the loop and strap arrangement is suitably versatile.
    Leaving the jacket in place is not only helpful if weather changes in the mountains, but also serves as a cushion for strapping down other items.
    Active Member a99miata's Avatar
    NW Florida
    might try using rivets to keep the surface flatter and away from the tires. just my opinion.
    Don't get mad at me if you don't like my answer.....
    Jan 2009
    austria
    great Idea for solo Ryders !!!!
