Results 1 to 15 of 15
Thread: Belt tensioner
    Active Member Sampi1099's Avatar
    May 2020
    Apache Junction Az
    Default Belt tensioner
    Ok I need help. I have a 2012 Can am Spyder RT Limited and I went to replace the idler wheel with the bigger one from Lamonster (LG-1065) and to my surprise there is not one on my spyder. Ok am I missing something here? I looked on the leftside and I took the Tupperware off all the way back to the saddlebags and nothing. Help!!!!!!
    Thank you
    Last edited by Peter Aawen; 05-30-2020 at 05:33 PM. Reason: Merged duplicate threads & title
    May 2020
    Apache Junction Az
    my 2012 rt limited does not have one? why not?
    Quote Originally Posted by Sampi1099 View Post
    Well actually it does ..... the ADJUSTERS at the rear axel, keep the tension at the level you want ..... Now if you mean ADDITIONAL idler wheel .... BRP sells them and so does LaMonster ..... His are way better ..... I don't have one because I lowered the tension to 150-160 lbs using the KritKit gauge ..... I measure mine while the rear tire is on the ground, it's so much easier and just as accurate ..... Mike
    Thank you
    I answered in your other Thread ..... Mike
    May 2020
    Apache Junction Az
    Thank you for your reply. I thought it came from BRP with one. Does it need another one added?
    Thank you
    Very Active Member StanProff's Avatar
    Jun 2011
    Jonesborough Tennessee
    At certain speeds the belt causes vibration, usually around 65 - 75 mph. It is not a bother to some folks but adding the idler roller will elimate
    It. It doesn’t come from the factory with one.
    Happy Spyderlovers
    May 2020
    Apache Junction Az
    Thank you. Who sells them?
    Sep 2009
    La Valle, WI
    Lamonsters garage. He has a website advertised on the home page. It's around 85 bucks.
    2018 F3 Limited , Oxford Blue
    Jun 2011
    I have ridden RT,s for going on 10 years, started with a 2010 998 then 2014 and presently a 2016 Special Edition triple black. I’ve run Lamonster’s idler pulley on the latest RT and it does smooth out the vibration. I recommend it. Good bang for the buck.
    Happy Spyderlovers
    May 2020
    Apache Junction Az
    Thank you but I looked on there web site and I did not see it.
    May 2019
    Carlton
    I have a 2012 Rt limited... I dont have one... I dont need one as mine runs smooth. If you dont have any vibration then you wont need this so dont just add it cos you think you should. I did however have a noisy belt which sounded like a transmission bearing problem. But a guy on here posted a BRP article on where to add grease on some of the rear sprocket teeth and all is quiet and good now!
    Dec 2013
    Which site?? Lamonster's??
    Just a quick look reveals this: http://www.lamonstergarage.com/belt-...-idler-pulley/
    Then there's also this: http://www.lamonstergarage.com/can-a...ley-lamonster/
    And if that stuff doesn't work, just putting 'belt' into the search field on the Lamonster Garage front page returns this:
    http://www.lamonstergarage.com/searc...ection=product
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    May 2020
    Apache Junction Az
    yes the Lamonster's site. I need the arm and the mounting bracket too
    Dec 2013
    Look at the description in the links, not just the pics. They sell the entire kit, exactly what you want; and not only is that detailed in the description, but they show you that if you scroll thru all the pics too.
    May 2020
    Apache Junction Az
    ok thank you
