Results 1 to 9 of 9
    Mar 2013
    Default F3 Top Box and custom rack
    Shad SH48 box with custom alum rack that mounts off the passenger hand rail mounts. Box is wired with quick release LED lights on top as well as LED brake light mounted below. the rack.
    All hardware to mount is included.
    Rack is made from 1/8" aluminum plate and welded. Extremely strong!
    Price is $150+ shipping.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2013
    Bump with new price.
    Aug 2019
    Stoughton, WI
    I see the grab rails come off. Wondering if it would bolt up with OEM Shad luggage rack hardware?
    2022 RT Sea To Sky
    Mar 2013
    Yes the grab bars come off then a set of thick round aluminum mount flush onto the mounts that are welded to the frame (factory grab bar mounts). This provides a larger mounting serface. The bolts with the saddle bag mounts then go through the side plates of the rack securing the rack and providing mounts for the saddle bags.
    I do not know what, if any difference there are between the mounting of the bag system that BRP sold (on my F3) and Shad ones, but if the Shad mounted off the grab rails then it should work.
    Nov 2019
    Kansas
    Would this work on an F3-T?
    Mar 2013
    Quote Originally Posted by acdcking12 View Post
    I just looked at our F3L and did a quick test fit. Looks like it will fit with no issues. If fact it would be easier due to no mounting for bags. This does sit over the passenger seat fairly tight to the seat so to remove the seat you have to remove the rack.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by PW2013STL View Post
    I have the BRP (made by Shad) mounts/saddlebags.
    2022 RT Sea To Sky
    Mar 2013
    Should work.
    Mar 2013
    I am now at best offer. The SH48 will fit two full face helmets and has the quick disconnect mount. This mount can be attached to a luggage rack if you want to have a passenger.
    Will work on the F3S and F3T.
    You will need to still pay for shipping. I will box it and get you a quote.
