Results 1 to 19 of 19
    Active Member MagYukon's Avatar
    Oct 2016
    Sherbrooke, Qc
    Default Best belt tensioner = No belt tensioner at all !
    Hi,
    Just my recent experience.
    In 2017, after a few rides with my 2016 F3T, I decided to put the BRP belt tensioner. Since then, vibration was gone and everything was fine.
    After reading many comments on failure of those tensioner, I pulled the trigger on the upgraded Pulley from Lamonster last year.
    When I removed the BRP one, after about 20 000Km, everything was looking just fine. so the replacement was more for a peace of mind.
    Las friday, I went back home from a very short ride and started to hear a very strange noise. As soon as I got home, I started my investigation to come up to a very bad, broken pulley which was probably starting to hurt my belt. By chance, everything seems to be OK on the belt.
    what the roller looks like new
    Since my first tensionner installation, I had my rear tire replaced and never tried the Spyder without my tensioner. To my surprise, it looks like the shop who did the installation of my new rear tire had adjusted my belt to the exact correct setup because I fell no vibration at all after removing the defective tensioner.
    That's why I think that the best of all Belt tensioner you can have is the one that you don't have to install on your Spyder !
    X-Grip Ram Mount Phone Holder, Lamonster Fog and driving lights, BRP Heated grip, Home made rear rack + Shad SH58X top case, BRP belt tensioner
    2016 F3T , Red
    Aug 2007
    Greeneville, TN
    That is really too bad having your bearing fail (which is what I assumed happened). I would think these little wheels turn at an astounding speed. It's good you caught this before you lost the belt as well.
    I don't think it is possible. Or at least reasonably possible, to get everyone's belt adjusted so that there is no vibration at all at any speed. You are very fortunate.
    One other, slightly off subject, thing I would like to mention is that these are not 'Tensioners', though you hear them called this all the time. They are Vibration Dampeners. They do not add any meaningful increase to belt tension. I hope everyone understands that their sole function is to reduce, or eliminate, belt vibration. 'Belt Tensioner' is a misnomer for this device.
    Oct 2016
    Sherbrooke, Qc
    You are right. it is not a tensioner. But it looks like it's what most people are calling them.
    My point was not really to scare anyone or to make bad comments on product. I just want to advise everyone to be aware of what can happend.
    And most of all, always listen to your Spyder. If you listen to it, you can prevent a lot of bad things.
    2016 F3T , Red
    Sep 2009
    La Valle, WI
    I like the belt Dampener. It makes my F3L smooth. I will always use Lamonsters. That said it is not a lifetime part. It is a maintenance item. I will change the roller out every 10,000 miles which is coming up in 2k miles. It looks fine but for 50 bucks every 10k it is much cheaper than a belt. It also gives me some peace of mind.
    2018 F3 Limited , Oxford Blue
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by MagYukon View Post
    My point was not really to scare anyone or to make bad comments on product. I just want to advise everyone to be aware of what can happened.
    Yes, fully understood. And not a bad time, at the beginning of the riding season, to mention it. Could same someone a belt for sure.
    After I got my new 14 RT home, one of the first things I did was to take some of the OEM tension from the drive belt .... I remeber way back when BRP had the tension way to high and there were quite a few Bearing failures .... I have run lower tension on all three of my Spyders and never had an issue .... that also removed 98% of the belt vibes I had....... annnnnnnnnnnnnnnnnnnnnnnnnnnd it was free .... I have discovered during my 73 years that there are folks who let " less than perfect " .... Ruin there lives ... I have high standards, but to me Perfect doesn't always have to be achieved ..... good luck .... Mike
    Jul 2016
    australia
    So mike what tension do you run.
    Apr 2020
    North Myrtle Beach
    Following. I was also thinking to loosen the tension a small amount.
    Quote Originally Posted by stu View Post
    I learned to use numbers that work while the Spyder is on the ground .... 150 -160 lbs using a KriKit II gauge .... Mike
    Feb 2019
    Portland, Oregon
    Here's a tip for prolonging the life of sealed bearings. Carefully remove the seal - it's just pressed in lightly - and add more grease to the paltry amount that's in there.
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    The best substitute for brains & knowledge is....................silence.
    Sep 2016
    Chillicothe, Oh.
    Seems everyone's bike reacts differently to the belt tension settings. I had vibration and installed Docs dampener. It worked great for just over 20,000 miles and it was starting to fail. Since the weather wasn't great and I was bored I decided to play with various belt tension settings. I went with the 160 on the ground as many use and the vibrations were bad. I kept going down all the way to 140 and no improvement. What the heck, lets go the other way just for giggles. I found a sweet spot at 180 measured with Kriket wheel on the ground. No vibes at all until 90 mph. I can live with that. 2015 RT ridden two up 95% of the time. No more dampener for me.
    2015 RT , Black
    Apr 2020
    North Myrtle Beach
    After years of Bearing Seminars and educations, 100% grease is not good.
    Aug 2019
    Battle Creek, Michigan
    What is the best to use?
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by FastOldGuy View Post
    On another thread, I added a shoulda sed. Clean the bearing of the old grease and do not completely fill with the new. Also, when I had my machine repair biz, the bearings I dealt with turned a lot slower than those on tensioners.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Deputy Dog View Post
    I would definitely use a high quality, fully synthetic, bearing grease. And I agree, more is not better in a sealed environment. You need only enough to coat all surfaces, and just a LITTLE bit more.
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    Once a side shield blows out it's open to all the moisture and road grit till it seizes up and stops rolling and chucks a ball bearing or 2 out the side.
    looks like that's what happened to yours.
    T.P.
    Jul 2016
    australia
    Thanks mike
    Jun 2010
    Las Vegas
    Hi,
    Totally agree, I had a “ million mile” tensioner that crapped out about 950,000 miles short and took out my belt.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
Tags for this Thread
